Kessler Kwik Plate Adapter for MoVI Pro & M5 back in stock!
Discussion in 'MōVI Pro' started by Mike Sutton, Nov 21, 2017.
  1. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    76
    19
    https://vimeo.com/kesslercrane/movi
    The Kessler Kwik Plate Adapter for MōVI replaces your MōVI camera mounting plate and its receiver and allows you to swap your camera from the Kessler Kwik Release Receiver on your slider or Second Shooter to your MōVI and vice versa without needing to switch camera mounting plates. No more waiting on plate removal and swaps in the field. Simply pop off your camera off your slider and lock it down on your MōVI within seconds. The Kessler receiver installs in less than 10 minutes (and lives on your MōVI) and offers the same clamping power as the stock MōVI plate receiver. The plate also features a safety latch so your camera cannot slide off the MōVI forward or backward. Our MōVI Kwik Plates offer multiple camera screw mounting points in both 1/4–20 and 3/8-16 so it will fit any camera mounting hole pattern. The Kessler MōVI Kwik Plate Adapter also has provisions for 15mm rod support and uses standard 1/4-20 screws to both mount the rods and the support.
    Currently available for MōVI M5 and MōVI PRO. http://store.kesslercrane.com/kwik-plate-adapter-for-movi.html
  2. Adam Kirby
    Adam Kirby New Member
    Jul 28, 2014
    13
    Does the Kessler MoVi Kwik Plate Adapter work with the Freefly rod adapter or do you have to purchase the Kessler rod adapter?
    I have both the MoVi M5 and MoVi Pro rod adapters so ideally wouldn't want to buy another one.
  3. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    76
    19
    Hi Adam. It does not as we standardized on 1/4-20 vs their metic screws. That said, we are doing a 15% off sale now till September 4th at midnight
  4. Martijn Martens
    Martijn Martens New Member
    Aug 6, 2018
    Hi Mike,
    Does the rod adapter bring the rods up to standard LWS height on RED DSMC2 cameras? Or do we need the additional height adjustment bracket for this?
  5. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    76
    19
    Hi Martijn. Ours is the same height as Freefly's which is standard
