Japan Law cant use 2.4ghz. To come under Japanese radio wave law i need to buy a JR 11x (special made) to make it work. the radio wave is 73mhz From my little bit of research I need to signal- sbus invertor solder to my MK FC http://www.quadrocopter.com/Futaba-SBus-Signal-Inverter_p_544.html then connect it to Futaba S.Bus Adapter Encoder then to my reciever and satellite (also special made) 73mhz to make it work? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBDXZ any help would be helpful? I have read other some other forums maybe i need this? http://store.diydrones.com/product_p/br-ppme.htm thanks for any help Jason
The MK board has the ppm connections on it. All you need is the S-Bus converter connected to you receiver and you good to go. But you have to solder the ppn inputs to the board. Here's a picture of the board you connect to #13 or this one for Futaba
thanks bill I thought you had to use the s-bus signal inverter like it says in the wiki?? http://www.mikrokopter.de/ucwiki/en/FlightCtrl_ME_2_1#Futaba_S.Bus_Receiver
