Is the Ignite Digi battery conversion kit! worth it?
Discussion in 'MōVI Pro' started by Azzie Scott, Jul 17, 2019.
  1. Azzie Scott
    Azzie Scott Member
    Jun 29, 2017
    55
    im strongly considering getting the ignite digii battery conversion kit. My movi Pro batteries just don’t give me long enough run time when I’m powering Movi with camera and accessories.
    Question 1: is it worth the investment to ungraded?
    Question 2: is Freefly planning to come out with better batteries for Movi Pro? Just want to know before I make the investment.
  2. Graham Futerfas
    1,257
    243
    Definitely worth it. Get the ones with Lemo ports, and they can make you a custom cable to give you an extra power port down by the cage for follow focus MDR’s
    None of us know the answer to question #2.
    Alejandro Selman likes this.
  3. Rolands Zelders
    Jul 27, 2017
    40
    totally worth it!!
  4. Rick Gerard
    Rick Gerard Active Member
    Apr 22, 2017
    172
    27
    I actually have both the Ignite kit and the standard batteries. I use both often. If I'm hand-holding or it's a really hot day or I'm over 5000 feet up flying the Alta I will put on the standard MoVI batteries because those TB 50 batteries are a lot heavier than the MoVI batteries. The Ignite batteries will run my Terra 4K or Sony A7's + full FIZ + Teradek Bolt + an Atomos Ninja V or Ninja Inferno for a couple of hours without any problem. The MoVI batteries will run the same gear for about 20 minutes.
  5. Jason Toth
    Jason Toth Active Member
    May 11, 2013
    308
    46
  6. Blake Scott
    Blake Scott New Member
    Jul 30, 2018
    1000% do get on the Ignite train. Also for weight you can run one at a time when doing a lot of handheld stuff and it shaves off some weight.
