Is it possible to balance M15 with 3 motors on a long Fujinon 18-55mm lens?
Discussion in 'MōVI M15' started by Siddharth Sharma SS, Mar 1, 2017.
  1. Siddharth Sharma SS
    Siddharth Sharma SS New Member
    Jan 17, 2017
    Hi,
    Has anyone has tried or have any suggestions on balancing the new Fujinon MK 18-55mm lens with Red Epic-W on M15 with three motors for focus, iris and zoom. Since it is a long lens it will create balancing issues with the motor weight that far forward as the camera package will move all the way back. Would be great to have suggestions for this setup.
    Thanks.
  3. Benjamin Granet
    Aug 31, 2015
    38
    10
    From the specs of the lens I've seen, I would say that you definitely can.
    I've already rigged multiple time zooms with 3 motors and I had no issues balancing them. After it all depend what FIZ you are using, what other accessories you want to ad and so on.
  4. Siddharth Sharma SS
    Jan 17, 2017
    Becca Ulmo likes this.
  5. Siddharth Sharma SS
    Jan 17, 2017
    I am using Wedge for FIZ and I attach it on top of the Red and upper boom in the M15 frame. That seems like the best way to balance it for me, for now. what do you suggest for a zoom lens like this?
  6. Benjamin Granet
    Aug 31, 2015
    38
    10
    It shouldn't be an issue with the wedge if you have light motors like the redrocks or Heden M21VE-L
    I usually attach the teradek on the side of the Red to had a bit of weight to counter front heavy lenses. If you still can't balance it, you could just had some counterweight in the back as you're probably gonna be far from the weight limit. The Cinemilled system is really nice but there is manny different options.
  7. Siddharth Sharma SS
    Jan 17, 2017
    Thanks. sorry for the late response. We use redrock motors. I will try and see how it goes.
  8. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    OK, two motors, but plenty space in the back... and no Fujinon but Optimo.... 2015-10-22 13.41.42.jpg
    Siddharth Sharma SS likes this.
  9. Siddharth Sharma SS
    Jan 17, 2017
    Thanks a lot for the Image. Very neat setup.
  10. Benjamin Granet
    Aug 31, 2015
    38
    10
    What I usually do is keeping the MAP-2 with rods and MSB-1 side brackets on the Alexa mini. It allows to put motors closer to the body so you could put one on the Iris, it also makes the body heavier to counter balance the front heavy load.
    The side brackets are also nice if you want to mount other accessories.
    It's also faster if you are on a set where you have to rig the camera during the day. Less shit to take appart.
  11. Mark Reedy
    Mark Reedy New Member
    Sep 16, 2016
    Siddharth if you haven't seen the great baseplate from Cinemilled then I recommend having a look. It's great for long and heavy lenses as you can add weights to the back of the camera to counter it. Also helps with the top heavy RED by having the weights sit low.
    https://cinemilled.com/shop/pro-dovetail-for-freefly-movi-m10-movi-m15/
    Not sure how you're powering your RED but if you are mounting the battery on the camera then it will work best with a side mount instead of a rear mount. You can buy a Wooden Camera one cheap and then just use your battery plate of choice (V-Lock or AB). I also got a custom right-angle red power cable to DTAP made up so there is even more clearance.
  12. Hamad Almuftah
    Hamad Almuftah New Member
    Jun 13, 2017
    The Fujinon MK 18-55mm Lens is an E-mount lens only, so It will only work with Sony camera. Unless there is an adapter from E-mount to EF or PL mount.
    I do own the lens and rigged it on the M15 with the Sony A7sII plus a redrock micro for focus only.
  13. Ryan Hawley
    Ryan Hawley Member
    May 14, 2014
    41
    Hi Hamad,
    What rail system are you using there? :)
  14. Ryan Hawley
    Ryan Hawley Member
    May 14, 2014
    41
    Hi Wolf, Can you briefly describe the rail / lens support system you're using there? :)
  15. Wolf Schiebel
    Aug 15, 2012
    254
    67
    ? I don't understand the question? It's the standard M-15 rail and toprail....
  16. Ryan Hawley
    Ryan Hawley Member
    May 14, 2014
    41
    Apologies - I know I'm most likely asking a question that has a forehead smacking answer. I just want to be sure I'm looking at parts that people like yourself actually use in the field. Specifically, I'm wondering what adapter you're using there to support the lens, that's attached to the Standard Freefly rod mount system?
    I've attached a photo here with an arrow pointing to it. Again, I know this is probably obvious, but I can't find the part and know that the professional users on here know their stuff. :)
    Thanks Wolf.
