Hey Thrill seekers.... After a very bad day of flying, I've decide to "Downgrade" from DJI A2 to Wookong. I never was able to get Data logging from the iOSD with the A2, which apparently is common, so am downgrading to get that feature back. While still on the bench, I powered up to verify that the log was giving me useful information, and saw two things that concern me. ON the first power on test, I heard all the motors jump in RPN for a split second. The data log confirmed that all 8 motors spiked +1,000RPM for a split second with no corresponding command from the throttle. (screen capture is attached) If they all twitch I'd probably be OK, but if only two of them did so....well I don't want to dig this thing out of the mud again. Should I be worried? If so, what do I look for as a cause? Second oddness It seems pretty common as well to see one or more of the motors vary in speed when I am giving commands only from the throttle. I would imagine that might be from me letting the stick go a little left or right and that it's trying to rotate a bit. Which if either of these things should be of concern? Share you thoughts...
