Iphone app firmware problem
Discussion in 'Software Solutions' started by Kasper Bröns, Mar 9, 2016.
  1. Kasper Bröns
    Kasper Bröns New Member
    Nov 19, 2013
    26
    Hi!
    Trying connect my Iphone to my M15 with the latest firmware but it says "firmware revision not recognized" anybody else experiencing this problem? solutions?
    Thanks!
    That usually happens if the iPhone app and the firmware are at different revision levels, Kasper.
    Did you update the iPhone app?
  3. Kasper Bröns
    Nov 19, 2013
    26
    Hi Andy!
    Yes i've updated it and reinstalled it. Tried everything but I'ts not working. Even tried changing phone
  4. Kasper Bröns
    Nov 19, 2013
    26
    I got the 1.630 version and akira on the mövi
  5. Andy Johnson-Laird
  6. As with all past firmware updates/releases, when you install a new version of the MoVI firmware, in order to communicate with the newer MoVI firmware, you will need to make sure you have an updated version of the MoVI app as well. MoVI App version 1.63 is not compatible with FW 5.0 BETA.
    **IMPORTANT:** Please download and read all the available [release notes](http://d27w8s76bjlz9v.cloudfront.net/wp-content/uploads/2016/02/08181024/Akira-Beta-Manual.pdf) prior to installing or using the BETA firmware.
    As per the FW 5.0 release notes, you will need to install app version that is compatible to the new version [here](http://freeflysystems.com/software-manuals/beta)
    The FW 5.0 BETA (Akira) user manual can also be found [here](http://d27w8s76bjlz9v.cloudfront.net/wp-content/uploads/2016/02/08181024/Akira-Beta-Manual.pdf)
    Software downloads by product/device can be found [here](http://freeflysystems.com/software-manuals/beta/software-by-product)
    It is under the MoVI APPS section of that link.
    The only way to take advantage of the iOS (not Mac OS) version of the app, is to have the [MōVI Wi-Fi Adapter](http://store.freeflysystems.com/collections/movi/products/movi-wifi-adapter)
    **The purpose of the Freefly Systems Beta Release is to test the software before Final Release. Problems found during the Beta Release should be reported to Freefly Systems via support@freeflysystems.com for review. You may participate in the Freefly Systems Beta Release testing by downloading the software and using it, however, you recognize that the software is of pre-release quality and using Beta software for production work is done so wholly at your own risk. The software furnished by Freefly Systems for this Beta release are provided "as is." Freefly Systems makes no warranty with respect to the software and shall have no liability to participant(s).**
  7. Andy Johnson-Laird
    Thanks for the detailed post, Chris.
    Hope that helps you, Kasper.
  8. Kasper Bröns
    Nov 19, 2013
    26
    Thanks for the help! works perfect now
