iPhone App and mount for checking vibration
Discussion in 'CineStar FAQ - Tips and Tricks' started by Colin Snow, Dec 5, 2012.
  1. Colin Snow
    Colin Snow Active Member
    259
    26
    You may have seen this elsewhere, but here's a solution to check motor vibration (propellers off!). The check is just a quick visual to see if one vibrates more than the others.
    App is Seismometer 6th
    https://itunes.apple.com/us/app/seismometer-6th/id362472189?mt=8
    Broom handle clips are Crawford #SS28 from Ace Hardware.
    Cheers - Colin
    Hi Coin:
    I use this Vibration app.
    Nice mounting clip though -- ingenious!
    Colin Snow likes this.
  3. Colin Snow
    259
    26
    Thanks Andy. Yes, I saw that app and didn't get it because it's $4.99. This one is $0.99. So, I kept true to my Scottish heritage. :)
  4. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    Andy i have the same.. what are the number you get with your motors???
    I take 0.02-0.05 without props..!
  5. Andy Johnson-Laird
    Aye, Jimme....wi' a nam' like Andrew Johnson-Laird, I ken, the noo....
    Hi Pavlos:
    Sorry...don't have the data to hand....I'll try and take some measurements this weekend.
  7. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    OK thank you...
    If you can put it with a rubber on the boom without gels and etc... as it is..!
  8. Andy Johnson-Laird
    Sure. You have to do that "hard contact" to get any decent reading of the vibrations otherwise the gels, etc. just absorb it.
    It may be this weekend before I have a chance to do this though! Sorry...tight deadline this week.
  9. Steve Maller
    This is ingenious. If I may ask, what does one do with this info if, for example, one motor is vibrating more than others?
  10. Andy Johnson-Laird
    Balance the motor and the propellers in combination. I don't remember the exact technique, Steve, but I did a Google search for:
    balancing motor and propeller​
  11. Pavlos Antoniou
    Oct 6, 2012
    321
    18
  12. Andy Johnson-Laird
    Is the "balancing tape" just that vertical strip of black tape, Pavlos?
  13. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    I use sellotape that is transparent i put small pieces in order to find the point..
  14. Andy Johnson-Laird
    Thanks, Pavlos. For the folks on this side of the pond, that's Scotch Tape. ;)
  15. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    Ok i am w8ing for your measurements
    Thank you
  16. Joe Azzarelli
    Joe Azzarelli Active Member
    Jul 13, 2012
    210
    26
    From this apps description:
    It acquires and displays time series data, optionally removes DC bias, applies a Hamming window and performs an FFT on each channel to produce frequency spectra"
    Ummm...huh?? ;)
  17. Tim Joy
    Tim Joy Active Member
    Aug 2, 2012
    405
    72
    I bought the Vibration app and it's definitely worth the 5 bucks. Found a prop that even though it was perfectly balanced, produced 1 g more vibes than the others. That's a LOT when other props were maxing out at .3 - .5 g. (This is g-force not grams btw) This was on an S800 and I hope that CS vibes would be much lower. :)
    I suggest hard mounting it to the boom using the boom clamps and a flat plate. The broom handle holder looks nice but I wonder if it's really making solid contact?
    Also suggest using a tach to read the vibes at the same rpm. A strap under the boom next to the motor will keep it from flying away.
  18. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    Can you try without prop and tell us how many g you see..
    i am between 0.02 and 0.05
  19. Colin Snow
    259
    26
    Great suggestions. I went ahead and got this app and it is much better at taking samples, snapshots, and making comparisons. I tried several broom clamps and this one is quite snug. The metal plate makes solid contact with the boom and provides enough surface area to hold the phone. I use a rubber band to keep the phone on the plate.
  20. Andy Johnson-Laird
    I wonder whether the hold-down strap over the boom alters the vibrations of the boom? Would it be better to have the hold down strap closer to the hub than the iphone? Obviously, the motor would then exert more leverage on the strap so it would need to be stronger...
