Ikan Remote Air 2 on Alta6
Discussion in 'ALTA' started by Kurt Naeslund, Apr 3, 2017.
  1. Kurt Naeslund
    Kurt Naeslund New Member
    Oct 24, 2016
    20
    Hello!
    I am looking into getting the Remote Air 2 from Ikan.
    Would that system have any interference with the radios on the Alta?
    Regards,
    Kurt
    Norway
    Kurt: The Remote Air 2 (according to the web page) operates in the same frequency band (2.4 Ghz) as the ALTA/Futaba command and control system, but these days the 2.4 Ghz systems use "frequency hopping" to avoid contention on the same channel from other transmitters.
    The short answer, therefore is: it should work.
    But I would proceed with caution, start by doing ground checks outdoors, and with, say, 75 meters between you and the ALTA and make sure you still have control of the ALTA (can you still arm/disarm the motors?), the gimbal, and of course, control via the Remote Air.
    The Ground Is The Limitâ„¢
  3. Kurt Naeslund
    Oct 24, 2016
    20
    Thank you very much for your input here Andy! :)
    Regards,
    Kurt
