I shot many weddings to afford the Movi Pro, please help
Discussion in 'MōVI Pro' started by frederic blake, Aug 31, 2017.
  1. frederic blake
    frederic blake New Member
    Aug 31, 2017
    So I finally have enough cash to make the purchase, however I am a noob and don't know what I need to get started. I have a Red Epic W with the DSMC2 Monitor. I've never used p taps and remote follow focuses and what nots, any help clarifying what I need is much appreciated!
  2. frederic blake
    Aug 31, 2017
    We just have the bare bones Red Epic W, no base expanders or anything
  3. Austin White
    Austin White New Member
    Aug 24, 2017
    What size Red Monitor do u have? I just got the Movi and my 7inch wont last more than 2 mins with the Movi Pro. I started running the Red Brick on it now. I guess it needs more watts to run the 7inch. Just a heads up.
  4. frederic blake
    Aug 31, 2017
    yes, the 7 inch. excellent to know. thank you.
  5. Jake Wilganowski
    Jan 5, 2017
    43
    My 7 inch works perfectly fine with movi pro
  6. Graham Futerfas
    1,221
    239
    HI Jake, which monitor cable do you use? Do you use a POGO to Lemo adapter from RED?
  7. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    234
    14
    you will have issues with the 7" DSMC2 using MoviPro Dtap connections/ non-red Lemo connectors
  8. Jake Wilganowski
    Jan 5, 2017
    43
    I use the wooden Camera top plate with lemo ports, I have a lemo 7" touch, not the pogo version
    I honestly don't see what anyone would use pogo anything
  9. Graham Futerfas
    1,221
    239
    Got it. It looks like the original poster of this thread has the DSMC2 Pogo version of the 7" monitor. I wonder if some of the power problems I've heard about might be related to the two different versions of 7" RED Displays. Just guessing, but maybe trying to narrow things down.
  10. Austin White
    Aug 24, 2017
    I run the wooden camera pogo version and can't get it to run more than 2 mins from freefly dtap connector.
