How does GPS Maxtenna install in movi pro I don't carefully check the PDF document about the installation instructions PDF explains the movi pro has built-in GPS module assuming that I want to buy this GPS module and whether need to buy separate cables should be installed in which place which port
That antenna is for older Movi’s, not Movi Pro. I don’t think GPS mode is supported for Movi Pro at this time.
There are two separate GPS modules already built into the GCU housing of the MoVI Pro. You do not need to install any GPS antenna on the MoVI Pro.
Here we need to ask whether the GPS will be blocked when movi pro is hanging under the uav. This is to ask whether this module will enhance the roll shaft stability effect
