I was attempting to install Akira. I had downloaded the new app to my Android tablet, but out of habit went to the old app when I went through the procedure and flashed it to Akira. Anyway, now I have 3 green lights but Movi is limp and not connecting to either old or new app. I'm afraid to turn off the movi, I don't have the jumper. I was going to try to update the firmware again in the new app, or downgrade the firmware in the old app, but I get this message. Is there anything I can do without the jumper?
You can make your own jumper if you don't have one. You need to short out pin 1 with pin 5. I did mine with a twist tie off of a loaf of bread when my movi randomly died. Do it at your own risk and with a steady hand. https://freeflysystems.zendesk.com/...-do-I-use-my-jumper-cable-to-recover-my-MōVI-
Thanks Mike. I finally shut off my movi and powered back up and it started talking to the new app, so all worked out OK after all.
@Mike: Bonus points for thinking of a twist tie from a loaf of bread! Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
