Hyperion charger problem!
Discussion in 'Electronics' started by hugo burns, May 5, 2014.
  1. hugo burns
    hugo burns Member
    Jul 26, 2013
    29
    Hi everyone,
    I have a hyperion EOS720i duo charger and all of a sudden the left charging port is not recognising that the balance port is conneceted.The other side works great.It's about 6 months old.I have tried everything...swapping the balance connectors,different batteries...but i haven't tried a firmwire upgrade.Anyone had this problem before?
    Thanks,
    Hugo
  2. Steve Maller
    My guess is that something in the balance port may have fried. That could be the end of that charger. Not likely a firmware update will do anything to remedy that. Do you have the Hyperion software? If you have the USB connector, you can probably see more info with their diagnostics. You can download the software here: http://media.hyperion.hk/dn/pc/pcsoft.htm
  3. hugo burns
    hugo burns Member
    Jul 26, 2013
    29
    Hi Steve,
    Thanks for the reply,
    Just cracked it open and everything looks good as new in there...no since of burning or damaged components.I might just have to give quadrocopter a call...
    I found this video....
    Thanks,
    Hugo
