If you want to reset the Radian module to the factory default values, do the following: 1) Run the Radian PC software 2) Write the config data without reading the current config first The module will now be configured for the roll axis - so change it as you need. In all other situations, read the current config from the module first to be sure not to lose your gain settings.
Was able to solve the problem thanks to Again, thank you so much .. ^ ^ go down the pan axis gain up to 30% It's stable. "
