How to invert display?
Discussion in 'MōVI Pro' started by Alex Sandman, Jan 27, 2017.
  1. Alex Sandman
    Alex Sandman New Member
    Jan 21, 2017
    the display of my Movi Pro's control unit is inverted. how do i flip it back to normal?
  2. Graham Futerfas
    1,261
    245
    Rebooting doesn't fix it?
    I've found it will boot up with the screen in the upright orientation, depending on if you're top mounted or underslung. If you pause motors and Roll Flip, that will invert the screen until you turn the Movi off and back on.
    Are you using Beta firmware or Original?
  3. Alex Sandman
    Jan 21, 2017
    thanks for the reply, Graham. the issue seems to have resolved itself, but is alarming nonetheless. it was definitely stuck in the inverted mode but then randomly switched back after 6 or 7 power cycles. i am on the original firmware.
    Graham Futerfas likes this.
  4. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Any chance you had the roll beam upside down?
  5. Alex Sandman
    Jan 21, 2017
    I don't think so but I'm not 100% sure. I am a Movi newb so I can't rule out user error, but I am pretty sure I remember the roll beam being right side up. I'll let you guys know if it happens again.
