How to Change Max Tilt Angle to limit more than allowed
Discussion in 'MōVI M5' started by Garrett Hurley, Feb 25, 2015.
  1. Garrett Hurley
    Mar 29, 2013
    34
    I am trying to find out how to limit the tilt because I am using the M5 with the Atomos Shogun behind my A7s and the hdmi cable going in to the Shogun will hit the side bracket on the M5 if you go much higher than horizon. I would like to limit the tilt up so this does not happen. I just don't see how to limit the tilt to this degree/
    Thanks!
    10,356
    1,161
    Garrett: Have you checked the M5 manual at page 04-P23 for Max Tilt Angle? Or did I miss the point of what you're trying to do?
  3. Garrett Hurley
    Mar 29, 2013
    34
    Andy,
    I don't have the M5 with me, so I am going to try to remember the range parameters from memory or give a hypothetical. I believe the max tilt goes from 0 to X. I went through the range going up. 10,20,30, etc and each allowed the gimbal to tilt past the point of what I wanted. I basically want the camera to only go about 10 degrees past horizon.
    Hope I was able to explain this correctly
    10,356
    1,161
    Did you write the settings out to the gimbal controller each time you changed them?
    I'm not in front of the M5 right now, but, going from memory the feature worked OK when I last tried it.
    I'll try and check tomorrow.
