So now that several of you guys have taken your MōVI Pros out on shoots, I was wondering how many batteries you find yourself needing for a day of shooting? If you're charging throughout the day, is 8 batts enough to keep things running without delay for 12 hours? Do different cameras/accessories seems to require faster battery swaps?
Good question. I have 12 batteries and 6 chargers. It's overkill if you can plug in all day, but if I had to go away from power for a while, it's nice. Different camera setups will use the batteries at different rates, obviously. For RED and Arri Mini, I'm drawing a lot of power because I'm powering camera through the Movi. For Canon and Sony, I'm using camera batteries and letting the Movi power the accessories, so the batteries last a bit longer. Also depends on if you're leaving the gimbal on for a long time, or shutting it down for periods of time. If I could plug the chargers into power all day, I'd say 8 batteries and 4 chargers would be comfortable.
I did 6 with 3 chargers. I wanted to test the waters before over buying. I see myself ending up with 8 batteries and 4 chargers as I mostly shoot on the Alexa mini and Red
11 batts 3 chargers. . . +1 for over 10 if you shoot in field a lot or leave it powered on (i was practicing switching it between alta yesterday, took a few mins a powering down would be annoying)
