Hi, i am a bit confused: i can not set the parameter of tilt, roll and pan hold strength independently. when i change one of them the other axis will have the same parameter. i reseted my M10 to factory calibration and default settings (because i have some problems and wanted to start from factory setting). Could this be the reason why?
Rolf not sure I am following your description. So if Tilt is 10 and Pan is 20 if you only change the Tilt to 15 the Pan then shows up as 15?
no - when i set Tilt (f.e.) to 5 then all other axis' are set to 5 too. if i change one parameter i change them all (same value)
Send a ticket to support@freeflysystems.com. You have an issue that I don't think has ever come up before.
did it and got the answer wich is as simple as it could be. the values of hold strength are in sync as long as the values are set higher than 10. i figured out that the MoVI performs much better (smoother) when the hold strength values are low, the camera is perfectly balanced and the stiffness is high.
Partly my fault. You said Hold strength and since we were talking about turning I was thinking Stiffness settings.
