Help with stabilization
Discussion in 'MōVI M5' started by Gustavo Torres, May 14, 2014.
  1. Gustavo Torres
    Gustavo Torres New Member
    Apr 16, 2014
    Hi: I´m having troubles with the Movi Stabilization is worst than handheld. I´m puting stiffness values higer as possible but the Movi starts to vibrating. I don´t know what to do, please help
    Thank you
  2. Steve Maller
  3. Rich Spiess
    Rich Spiess Guest
  4. Gustavo Torres
    Apr 16, 2014
  5. David Cooper
    David Cooper Member
    Mar 22, 2014
    30
    The Movi app does NOT save settings automatically. You need to save any changes to write the settings to the Movi.
  6. Gustavo Torres
    Apr 16, 2014
    I save the settings, but you can see in the image a bounce when I walk
  7. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    Would you mind posting video shot from the Movi with what you mean?
  8. Andy Johnson-Laird
    Hi Gustavo:
    The MōVI cannot remove vertical or left/right motion -- it can only remove rotational motion. You will still need to walk carefully otherwise your up/down and left/right motion will be visible.
    You might find this thread worth reading: http://forum.freeflysystems.com/index.php?threads/operating-advice.2471/#post-45170
  9. Gustavo Torres
    Apr 16, 2014
    I will set the Movi again and make some shots. Maybe I'm losing some step
