Help, New Firmware 3.08 not working
Discussion in 'MōVI M10' started by Jim Robertson, Jul 17, 2014.
  1. Jim Robertson
    Jim Robertson Member
    Oct 24, 2013
    34
    I just updated to 3.08 FW and it said it was complete i repowered the movi and now the three green lights come up right away but the bluetooth connection isn't happening at all. it sees it she i go to connect and immediately disconnects, so i can't see any settings to even install the old version. what am i doing wrong and what can i do to fix this
    Please help
  2. Senthil Nathan
    Oct 31, 2013
    62
    Are u using the software on PC Mac or ios. Cause u can try a different platform. This happened to me on my PC but when I tried again using my Mac, It worked flawlessly. Hope this helps.
  3. Andy Johnson-Laird
  4. Jim Robertson
    Oct 24, 2013
    34
    i did it on my mac however now it does not connect via blutooth at all
  5. Jim Robertson
    Oct 24, 2013
    34
    i have and am standing by for help
  6. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    You need the latest Configurator app which was part of the 3.08 update package. Can you confirm you have installed the latest app, 1.552 for MAC?
  7. Jim Robertson
    Oct 24, 2013
    34
    ok i had downloaded the newest Configurator app but my mac was still pulling up the old one. and it is confusing because the old one is 1.522 and the new one is 1.552 My bad, thanks guys.
  8. Brad Meier
    Aug 14, 2012
    749
    66
    No problem.. Glad it was an easy solution.
  9. MIke Magee
    MIke Magee Active Member
    422
    103
    Good catch and heads up. I hate when the version numbers do that. 1.6 would have been appropriate for a major drop.
    -m
  10. Augusto Alves da Silva
    Augusto Alves da Silva Active Member
    Apr 16, 2013
    202
    39
    My 3.08 installed and working great and auto tuning worked fine. But now I hear the Pan motor whenever I turn the handle to Pan. Is this normal? I tried to lower the Stiffness on the Pan Axis but still hear the same noise. It really sounded like the Stiffness was set too high on the 3rd axis. It is at 83 with a 5DMKIII and a 16-35mm.
  11. Brad Meier
    Aug 14, 2012
    749
    66
    You may have some sort of mechanical connection that has become loose. Check all the bolts for tightness on your MōVI.
  12. Marc DIDIER
    Marc DIDIER New Member
    Jun 10, 2014
    hi,
    i did the up grade but couldn't finish because my computer (mac)didn't have enough space...
    now the movi can't start, 3 green lights when powering then nothing.
    The configurator (last version) sees the movi but can't connect.
    is there a way to reflash via a cable or anything else ???
    thanx
  13. Gary Haynes
  14. Marc DIDIER
    Jun 10, 2014
  15. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    is it safe to update the firmware?
  16. Marc DIDIER
    Jun 10, 2014
    yes it is, but be carefull that your device running the configurator won't stop during the procedure
  17. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
  18. Marc DIDIER
    Jun 10, 2014
    tu do the upgrade you 'll use , let say, a coputer, communicating with the Movi via bluetuth., before to launch the upgrade, make sure that your computer won't go for a screensver, won't shut down because of the battery, that the movi has enough battery as well...
  19. Markus Mueller
    Oct 19, 2013
    63
    Hello All,
    I have a problem with my mac installing the new firmware. I´ve downloaded the new firmware : Freefly Configurator_1.552.pkg, but my mac says installation on this computer not possible. I´m still running on OS 10.7.5 - is that the problem ? The older version of the app is running without problems.
    Any ideas ?
    thanks Markus
  20. Andy Johnson-Laird
    Markus:
    I tried installing it on 10.6.8 and I get the same message. I'm not quite sure which earlier versions work so I've emailed Freefly.
