Help needed with the Update
Discussion in 'MōVI M15' started by Giles Harvey, Feb 17, 2016.
  1. Giles Harvey
    Giles Harvey New Member
    Sep 20, 2013
    20
    Hello All,
    Have connected M15 to computer app. Downloaded the update and throught the app began the update process. Told me me update was succesful and now thelights come on but movi is lifeless. Anyone suggestions to what I can do?
    Comms revision not recognised is my error message
  2. Giles Harvey
    Sep 20, 2013
    20
    I have used the jumper cable and the firmware says its successful but once powered down and the jumper removed, movi is re-powered but it is still bricked. Thoughts?
  3. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    235
    14
    Did you upload your previous settings after you updated?
  4. Giles Harvey
    Sep 20, 2013
    20
    It is totally unresponsive and has no option for updating settings
  5. Roy Mills
    Roy Mills New Member
    Dec 3, 2014
    22
    i got the exact same thing. I assume you have updated the app as well ? if so try updating back to the last firmware using the jumper cable. I done that and it manages to boot back up fine.
  6. Bryan Edmonds
    Jul 3, 2014
    248
    126
    The Comms Revision Error means that you were not using the app that matched the firmware you loaded on the MōVI. That is not an indication that the unit is bricked and needs a jumper cable to be recovered.
    The beta apps can be found further down the page, in the MōVI Apps section.
    For further support, please contact your dealer, or support@freeflysystems.com
  7. Roy Mills
    Dec 3, 2014
    22
    did you manage to sort out the new update ?
  8. Giles Harvey
    Sep 20, 2013
    20
    All sorted now. It took a while but have successfully uploaded the new firmware and the app on my iphone. So far the timelapse in 6K on the weapon is off the charts. This is going to be fun!
  9. Roy Mills
    Dec 3, 2014
    22
    w
    was it still bricked after you updated the app ?
  10. Giles Harvey
    Sep 20, 2013
    20
    No. Once I got the right app. (which has to be applied for) then I was able to operate the movi just fine. The new options are off the charts
