I bought the Movi Pro about 30 days ago. I watched all the videos and balanced the Movi Pro correctly. My pan, roll, and tilt in the balance menu are staying in the green. However, when I walk, I get this side to side pan drift with my Canon C200B mounted. Is this a menu setting in the app causing this? Any help here would be great to stop this drifting side to side when I walk. I don't have this problem with the Freefly M5 with my Canon 5D mark 4, so I'm pretty sure I shouldn’t have this problem on the Movi Pro. If I can't get this to work, I would love to send this back to Adorama, but the 30 day return policy just expired. Any help would be appreciated.
Hi Travis: That side-to-side drift doesn't sound right....if I were you, I'd open up a ticket by sending an email to Freefly Support (support@freeflysystems.com) and ask for their help. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
This sounds like an issue with your settings. You could do some screen grabs in the app and post them here, for convenience. What are your Smoothing and Window settings? And your hold-strengths? This can sometimes happen if you have the settings out of whack, like a really high Smoothing setting. Try toning that down and see if your problem goes away. It could also be a low Pan hold or motor stiffness (or high filter?). I advise you to try taking your settings to extremes and see what that does to the Gimbal's response. I often say I can make the Movi feel like a sports car or like an old Cadillac, depending on what I'm trying to do.
Graham's right -- I inferred that you had done an autotune holding the MoVI as you intend to use it, but if you've been tweaking settings post autotuning, follow what Mr. Futerfas done said! It might be the pan stiffness setting, but there are interactions with other settings too.... Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Thanks for the reply, Andy and Grahm! I'm going to set everything up and take a look again and screen grab some screenshot settings and post back.
Window at 0 is your main culprit, under Majestic Settings. That is probably the source of your problem. My personal preference is a Window at 3 or 4, but I've seen people who like a higher value. Window corresponds to how far you have to pan or tilt before the Movi responds (in degrees), but if it's at 0, then the stabilizing feature is basically turned off. Higher windows ignore your inputs more --- good for running or fast movement where you want to filter out excess inputs from your panning. Lower windows are good for fine-tuned, precision moves.
You're welcome, always happy to be able to help, plus I get to learn from your problems. >Also is there a systematic order for the settings in the app when balancing? What do you mean by this question? At first I thought you meant Auto-Tune, but maybe not? I always Balance the gimbal before turning it on and changing settings, but maybe you're asking something different?
Graham, I think by "systematic order" Travis is asking is there an optimal sequence in which to balance the axes? If so, then the answer is that I prefer to do tilt, roll, and pan, then rinse and repeat as required (because there are interactions). I agree with Graham re: Window = 0 -- that's effectively turning off Majestic. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
