Having a lot of trouble with Redrock Focus barely moving, urgent (+ video)
Discussion in 'MōVI Pro' started by anthonysneed, Apr 1, 2017.
  1. anthonysneed
    anthonysneed Member
    Oct 15, 2013
    36
    [SOLVED] I bought the Focus cable for the movi pro, plugged it into the redrock focus torque motor and went to the FIZ section on the controller. I tried adjusting all the dampening, speeds, etc but it barely moves the motor. Like miniscule amounts. (I do have a micro remote but i was told I don't need it for the new movi pro with the cable)
    I uploaded a video showing the problem. I have a shoot tomorrow and need help fast. Thanks!
    #1 anthonysneed, Apr 1, 2017
  2. Andrew Agcaoili
    Andrew Agcaoili New Member
    Mar 31, 2015
    13
  3. Katya Nelhams-Wright
    Jul 8, 2012
    216
    Hi Anthony
    What lens are you using and how are you calibrating the motor. Does it calibrate correctly?
  4. David Beard
    David Beard Member
    Nov 15, 2016
    41
    Your torque setting is at 1, the very lowest. Bring this up incrementally until the motor will calibrate the lens. Be careful not to go too high, and this will allow too much current, and overheat the fiz motor.
  5. anthonysneed
    anthonysneed Member
    Oct 15, 2013
    36
    Actually I emailed Freefly and they helped solve the problem very easily. I needed to calibrate via the controller under the FIZ section. It was super easy. The reason why there was such little movement is simply to show you it's connected until you calibrate then you're good to go.
    Chris Harrison likes this.
  6. Ryan Sheets
    Ryan Sheets Member
    Jan 26, 2014
    35
    I have this issue...can you talk about how to calibrate?
    Can you
