Great Custom Made Power Solution For M10/M15
Discussion in 'MōVI M15' started by Ben de Graaf, Dec 4, 2014.
  1. Ben de Graaf
    Ben de Graaf New Member
    Sep 6, 2013
    20
    This I have specially made for the M10 and M15.
    2x BNC D-Tap and 1 SDI in at bottom. At the top 1x SDI out and a connection for feeding the Movi.
    Under the handle 4 additional Dtaps.
    Ikbal Arafa likes this.
  2. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Hi,
    that looks good, the only problem is that you can´t power the M-15/10 with a v-lock battery, since it-s shutting down at 14.5 Volts.
    These gimbals need a 4S Lipo to work properly. That´s been tried and discussed several times...
    Best,
    Wolf
  3. Shaun Gish
    Shaun Gish New Member
    Aug 18, 2013
    I'm assuming that the v-lock battery may be to power the accessories using the d-taps. At least that's how it looks like it would work to me.
  4. Peter Barta
    Peter Barta Member
    Sep 24, 2013
    75
    21
    Hi Ben,
    Clever idea are you selling these? and if so how much? Thanks
    Pete
  5. Ben de Graaf
    Sep 6, 2013
    20
    it's made at a small company in the Netherlands for about 800 US.
    I think only the parts are not for sale http://www.etkon.com
  6. Kevin Descheemaeker
    Sep 16, 2013
    59
    Hi Ben
    Interesting item you have there. We are based in Belgium and interested in your product. But what Wolf and Shaun telling is something what we also doubt.
    Can you give us some more information on the powering systems trough the V-lock? Do you power the MoVI as well or only the accessories?
    Grtz
    Kevin
  7. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    138
    21
    Guys, I don't think Ben is trying to power the gimbal with a V-Lock battery. It appears its for the accessories. The design is great because it's putting the weight of the V-Lock battery above the handle bars, which doesn't count towards the M15's max weight of 15 pounds. If you've ever used a Canon 1D-C, BMPC, or other awkward shaped cameras, powering the accessories can be tricky. This design creates a great power solution without adding weight to the gimbal.
