Graupner Telemetry on Alta
Discussion in 'ALTA' started by Andreas Riem, Nov 13, 2015.
  1. Andreas Riem
    Andreas Riem Member
    Oct 28, 2015
    43
    Guys,
    as Graupner pilot I'm used have telemetry with full-cell-monitoring. Therefor I want to use the Graupner Electric-Air-Module also on my Alta, but I'm little scared about the 150A current (peak 1 second 320A). Does anyone has any experience with this or is using the same stuff?
    Here some pics how the implementation actually looks like. Don't like that much, better ideas very welcome.
    Cheers,
    Andreas
    Andreas if all you need is simply the voltage I wonder if you could simply use the supplied power tap that plugs into the Futaba RX. It is simply providing the voltage value. Then you eliminate adding a failure point to the power supply wiring. You wouldn't have amps but not sure the the Graupner unit reports amps.
  3. Andreas Riem
    Andreas Riem Member
    Oct 28, 2015
    43
    Gary, I see your point with the wiring, but only in that case Alta regularly uses more than 150A current for longer than 2 seconds. The Graupner module provides cell-voltage, used capacity (mAh) and general voltage. I my eyes the cell-voltage is the most important information. We're using only first class batteries form Tattu - but sometimes it happens that you get a sick one and you are lucky to see the cell-drop early enough.
  4. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy,
    I use this Air module on my ALTA too. So far without any problem. Even when flying 16 kg gross it worked fine.
    But I only use it on 1 battery, so if something happens to the air modul I still have 1 battery to land safely. (kopterworx recommended)
    (This mean I have to multiply the current by 2 when i check it)
  5. Andreas Riem
    Andreas Riem Member
    Oct 28, 2015
    43
    Hi Adam, can you post of send me a picture how the air module is implemented onto your Alta?
    Cheers, Andreas
  6. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy Andreas,
  7. Andreas Riem
    Andreas Riem Member
    Oct 28, 2015
    43
    Thanks Adam!
  8. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    If you have any questions let me know!
  9. Cédric Bourgoin
    Cédric Bourgoin Distributor
    Aug 21, 2012
    65
    Hi Guys,
    I see that you use Graupner system. I have had a hard week end trying to set up a GR 24 PRO on an MC20. I didn't manage to make it work.
    I have found no where how to set up the GR 24 PRO in SUMO 12 mode :/
    What Rx are you using on your ALTA ?
    Thanks in advance ;)
    best regards,
    Cedric
  10. Andy Johnson-Laird
    10,364
    Salut Cedric:
    Ca va?
    As I recall, to enable SUMO on a receiver you have to do it via the telemetry screen on the MC-20.
    This shows how to do it: http://wiki.mikrokopter.de/en/MC-20#Set_the_receiver_to_sum-signal
    But that said, I am not sure the that GR 24 PRO actually supports SUMO? There is no mention of SUMO in the "manual" at http://www.graupner.de/mediaroot/files/33579_33583_Manual_DE_EN_FR_IT_web.pdf
    I recently had to order several GR-32 Rx's from Germany because the GR-32L's (and other L models) on-sale in the USA no longer support SUMI -- and I'm not sure whether they support SUMO.
    I have no idea what Graupner is playing at by segmenting the market like this and presuming that removing existing features is a way to win loyal customers in the USA. It seems both arbitrary and pointless. Grrrrr.... :mad:
  11. Andy Johnson-Laird
    10,364
    Adam:
    Could you describe the steps you took to install the Graupner Air Module, please?
    It looks like you have both XT60 LiPo wires configured in a Y-connector and feeding through the Air Module? Is that correct?
    A simple wiring diagram would be very helpful.
    I am just concerned that if people want to do this that they need to do it properly to avoid problems.
  12. Cédric Bourgoin
    Aug 21, 2012
    65
    Salut Andy, toujours un plaisir d'échanger un brin de français avec toi ;)
    I have had hard time this week end with no results.
    The GR24 PRO is sold to support SUMO, SUMI,SUMD but .... guy, you can't have it to work in SUMO ! no way to configure it thry telemetry system in SUMO. SUMD yes, SUMO or SUMI : no .
    And effectively, in the manual: no trace of SUMI and SUMO ...
  13. Andy Johnson-Laird
    10,364
    Cedric: Je me réjouis de la possibilité d'écrire en français - même si je dois avouer que je besoin de l'aide de Mme Google pour vérifier que je ne suis pas en train d'écrire comme un idiot.
    Il semble bizarre que Graupner / SJ semblent avoir retiré SUMO / SUMI? De ce que vous avez trouvé, il apparaît que SUMD est maintenant un remplacement pour SUMO / SUMI?
    Dites-moi qui est pas vrai, s'il vous plaît ...
    I welcome the opportunity to write in French -- even though I need the assistance of Mme Google.
    It seems bizarre that Graupner/SJ appear to have removed SUMO/SUMI? From what you have found it appears that SUMD is now a replacement for SUMO/SUMI?
    Tell me that is not true, please...
  14. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Hi Adam,
    Just a question about the battery connectors that you are using. Are you sure that they are rated to supply enough power? if they are xt60 connectors, I would be concerned that they wouldn't be sufficient. With an approximate 4.2kg payload my Alta motors are pulling an average of 156A. This would be too much for xt60 connectors right? And would be getting close to what the xt90 connectors are capable of. Am I right, or am I misunderstanding something?
    Cheers,
    Alex
  15. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy, I knew that the XT90 are rated at 60A. This is why I tested them to see what can they handle.
    At 24V one connector can handle 100A for 2 hours at around 40 celsius. At 120A they went up to 48 celsius. After this I'am confident about these connectors. Used them with my cinestar for a long time without any problem.
    alex ryan likes this.
  16. Andy Johnson-Laird
    10,364
    Did you happen to do any tests on EC3 and EC5's, Adam?
  17. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    No, only used EC5 on my T-Rex 700E. That used 160-240A currents and the EC5 only got a bit warm, so it could handle this.
    Never used EC3.
    I only switched to XT90 because it has the antispark version, wich is better, since the sparks won't ruin the connectors, and it won't give the electronics such a big shock when connecting.
  18. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    One side note about the XT90S. I fyou don't push it all the way together and start flying/chargin you gonne have a small pop when the resistor blows up. :)
  19. Andy Johnson-Laird
    10,364
    I presume what happens is the anti-spark resistor, which is only designed for low current, suddenly gets hit with high current and then, as the saying goes, "the resistor turns into a fast-blow fuse."
  20. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Yes, I blow up one while testing on my charger/DC. It smelt terrible. :)
