Graupner GR-24 Channel Problem
Discussion in 'Radian' started by Philipp Haefliger, Feb 27, 2013.
  1. Philipp Haefliger
    Philipp Haefliger New Member
    Aug 14, 2012
    19
    Hello
    Is it possible that only 8 channels can be used?
    I have a GR24 but there are only 8 channels displayed (SUMO-12), channel 9-16 are the same as channel 1-8.
    But i need channel 9-12...
    Thx
    Philipp
    Phillip what transmitter are you using?
  3. John Cunningham
    Jul 5, 2012
    183
    13
    Philip,
    The Radian does this to allow two receivers to be used at the same time and it's very useful for dual-operator ships.
    However, there will a new version of the Radian software soon which will allow you to turn this feature off - so you will be able to use all the PPM channels (up to 16 if the Rx supports them).
    We just need to test the new release a bit first so please be patient ...
  4. Philipp Haefliger
    Aug 14, 2012
    19
    My configuration:
    Octocopter with GR-24
    3-axis gimbal with GR-24
    Transmitter MC-20
    Philipp
  5. Philipp Haefliger
    Aug 14, 2012
    19
    Release date? I need it ;)
  6. James Laver
    James Laver New Member
    Apr 5, 2013
    I have the same issue, but with mx-16 and GR-16. I don't need the de-duplication as such but was a little confused when I moved the sticks and watched the PPM inputs on 'Monitor'.
  7. Philipp Haefliger
    Aug 14, 2012
    19
