Hello, unfortunately the GPS antenna solder points on my M15 mainboard snapped. All three contacts are stripped of the board so there is nothing left to solder a new SMA jack too. The Movi M15 still stabilizes well but of course shows zero satellites. How difficult would a replacement of the mainboard be? Is it possible to order just a new board without having to send the complete gimbal in?
Or would it be possible to use a M10 mainboard instead? Like in this topic: https://forum.freeflysystems.com/in...mimic-m5-motherboard-for-m10.8724/#post-74659
Andreas, if you've not already done so, I suspect you should open up a ticket by sending an email to Freefly Support (support@freeflysystems.com). Regards Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
