Gimbal vibrations
Discussion in '2 Axis Gimbal' started by recrecords, Nov 26, 2014.
  1. recrecords
    recrecords New Member
    Nov 26, 2014
    Hi
    I have DJI Phantom 2 of 2 Axis Gimbal founded in the pictures you can see that cable connection, it should be correct. In the vertical plane during the flight gimbal gets seizures, which can be seen in the video posted.
    [youtube]
    Another problem is the reaction on the levers gimbal movements in the vertical plane (the camera is pointing straight ahead and performs gentle movement upwards instead of down).
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    PS Google Translate
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    839
    67
  3. Jason Smoker
    Oct 23, 2012
    839
    67
    Just so you know this a freefly forum not a Phantom forum. There is a Phantom forum here which probably better for your needs
    http://www.phantompilots.com/
    Looks like you have a couple of problems though. Firstly get rid of those prop guards and string for smooth video these are not required. Secondly your props look like there cheap flex ones which will cause vibration. Thirdly you might want to look at gimbal settings. GOOD LUCK!
    10,356
    1,161
    Thanks, Jason! Go dude!
  5. Jason Smoker
    Oct 23, 2012
    839
    67
    Thanks Andy just doing my part!! hahaha
