Hello everyone i have got my a gh2 camera for testing with my cs 8 i just wounder if anyone use this ,and have some good setting for best aerial filming? how do a set it to the best quality for filming? thanks
Do a search on the Forum for GH2 and Jeff Scholl. Also you can see his videos on Vimeo and YouTube. He and many others use the GH2 with one of the many firmware hacks.
I would recommend that you do not use the HBR setting as this is interlaced and does not work well for aerials.
HBR stands for "High Bit Rate" which means it has a high data transfer rate which one would assume to be a good thing. This setting looked fine on the ground, but the aerials looked blurry, so this setting should be avoided for aerials in my opinion. I found that manual movie move set to 80 percent speed worked well (this is actually 30 frames per second.)
