OK. First off, I did a search and came up with nothing... I am trying to fire my Sony NEX7 with a gentles led shutter release through the tilt radian. I have it plugged in to port 6 (I believe this is right) and have set the AUX on the tilt to the proper channel on my DX8. I can see the input monitor respond to the three way switch so it seems that that connection is working but the camera isnt firing. Did I plug the gentles led into the wrong port on the radian? Any help or thoughts with this? EDIT OK... yeah. I wish I could delete this as I am such a dunce. Anywho, in the hopes that someone else may find this useful: Plug the gentles led into port #2 on the radian. All is well.
You should be able to delete it -- look below the main message area to the left of the Like/Reply buttons and you should see Delete. And you are correct, Port 2 is the Aux port. Andy.
