Does anyone have the link to buy the gamepad holder? Been searching online but not exactly sure what to search for. Looks easy enough to customize to fit the Mimic and controller. Will be sure to post my results when I get it. Damn... where is this going to fit in my case!?
Hi Rob, https://www.amazon.com/Sony-GCM10-C...1485307610&sr=8-1&keywords=sony+gamepad+mount I took a drill to one today. Pretty easy, but I currently can't get the controller to work with the Mimic...
I bought the same mount but took a 1 1/2" 1/4 20 bolt, ground down the back half flat on either side and drilled a hole through it. Replaced the suction cup with the bolt and now I can twist on the Mimic and quickly tighten it down with the thumb latch. If anyone is interested, I can post pics tomorrow.
I took a 1 1/2", 1/4 20 Bolt, cut off the head and ground down two opposing sides so that it would fit into the suction cup mount (removing the suction cup and leaving the outer plastic "cup"). I drilled a hole for the thru bolt. The bolt ended up being about 1 1/4" long and I left about 1/4" of thread. Once you remove the cover on the holder, you will see how easily you can remove the cup and insert screw. Mine only takes about one full turn to attach Mimic and then I can flip down the thumb latch to tighten the connection. Works great. I had the dremel so it only cost about $1.50 for the screw. Obviously, Graham's is much easier and quicker.
