FUTABA T10J + MOVI M5
Discussion in 'MōVI M5' started by lukasz wijas, Dec 2, 2014.
  1. lukasz wijas
    lukasz wijas New Member
    Oct 5, 2014
    Hello,
    I bought FUTABA T10J + R3008SB reciver and I can connect to movi?
    Reciver is bind. Movi software can't see radio controler?!
    Please help!!!
    Lukasz make sure you change the receiver type in the MoVI GUI.
  3. lukasz wijas
    Oct 5, 2014
  4. lukasz wijas
    Oct 5, 2014
    i change to SBUS
  5. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    858
    67
    I believe you will have put in a s-bus and connect to your R3008SB receiver. Otherwise the m5 wont
    recognize the Futuba.
  6. Akekapong Homhirun
    Akekapong Homhirun New Member
    Jun 19, 2014
    Jason, How to fix this problem.please advise
  7. Jason Smoker
    Oct 23, 2012
    858
    67
    So you need a s-bus encoder.
    http://www.futaba-rc.com/sbus/futm4194-lg.jpg
    Then take off the two screws where the spektrum cable is. remove this cable this not required then plug in your s-bus encoder into the slot. then from your s-bus encoder just plug in the cables into your R3008SB receiver. Then change the receiver type in the MoVI GUI to s-bus. You will then need to program the channels using the movi gui
  8. Justin Oakes
    Justin Oakes New Member
    Jan 5, 2015
    We only use Futaba products so I know exactly what your problem is.
    The Futaba T10J ships with a telemetry enabled receiver unit that won't work with Freely products. This is the same issue others have experienced with the receivers that ship with the Futaba 14SG and 18MZ.
    To fix the problem, you just need to buy a different receiver. The kit R3008SB transmits on T-FHSS ("T" stands for telemetry). You need the S-FHSS ("S" stands for surface) version of that receiver.
    Buy this and everything will work normally, although you won't get telemetry data back to the transmitter.
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBPKN&P=ML
  9. Christopher Morrison
    Oct 23, 2015
    I have The Futaba T10J & the Futaba R3008SB working with the MOVI M5. The only thing I cant figure out is the Pan which for my Multirotor application that is the most crucial control. If anybody has any tips or advice You input would be greatly appreciated Thanks
  10. Gary Haynes
    Christopher check your channel mappings on the both the radio and in the MoVI gui. Might simply be a channel mismatch.
  11. Christopher Morrison
    Oct 23, 2015
    Thanks Garry Where do I find the channel mapping in the GUI?
  12. Gary Haynes
    See Page O4-23 in the M5 manual. Then find the same information for channels in your Futaba manual.
