Futaba R7008SB 2.4GHz FASSTest Receiver
Discussion in 'Radian' started by Daisuke Ide, Jan 4, 2013.
  1. Daisuke Ide
    Daisuke Ide Distributor
    Jul 26, 2012
    34
    I was connected Radian to the S-BUS port of New Futaba R7008SB Receiver.
    This receiver is the specification of the new 2.4GHz FASSTest to support S-BUS2.
    It did not work unfortunately.
    S-BUS2 is a two-way communication for telemetry.
    I changed the Receiver setting to original S-BUS mode is not necessary since S-BUS2 in Radian.
    I was the same as the results. Do you support the S-BUS2 Radian?
    10,369
    Daisuke: JohnC is the man who can answer this -- perhaps Tabb -- but I'm afraid I do not know.
  3. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Hi Daisuke, I am not sure on Sbus2 yet, I have not tried it myself. It seems as thought the receiver has a standard Sbus port as well so I would use that for the time being.
    Tabb
  4. Nico Turini
    Nico Turini New Member
    Aug 14, 2012
    22
    Hi FF team,
    We have the same problem with this receiver on the radian system. It doesn't work anymore. Any support would be appreciated :) Thanks!
  5. Tabb Firchau
    Jun 28, 2012
    911
    472
    Are you using the Sbus2 or standard Sbus port?
    Tabb
  6. marc marchand
    marc marchand New Member
    Aug 10, 2012
    hello Tabb
    I work with nico
    We use the SBus port
  7. Martin Haemmerli
    Martin Haemmerli New Member
    Oct 15, 2012
    10
    Hi
    I do have the same issue. Radian worked fine with the Futaba R6208 SB but with the R7008SB it's not working. Not on S.BUS and not on S.BUS 2.
    Do you have any workaround for this?
    Thank you.
    Martin
  8. Andy Johnson-Laird
    10,369
    Let me ask JohnC, the Radian designer, Martin.
  9. John Cunningham
    Jul 5, 2012
    183
    13
    I haven't seen one of these receivers yet : I expect Futaba have changed the protocol slightly in some way.
    I will certainly add support for it once I know what the differences are.
  10. Martin Haemmerli
    Oct 15, 2012
    10
    Hi John
    Do you have an update on this?
    I still have to use 2 tx to operate the copter.
    Thank you.
    Martin
  11. Daniel Doren Huerta
    Nov 30, 2012
    31
    Hi I'm from chile and my name is Daniel...
    I have a Futaba Radio T18MZ with two different R7008SB receiver, and both have problems to connect with Radian... I am 100% sure that there is nothing wrong with S.Bus fro this receiver as they work very well with my WookongM or with NAZA through the same port...apparently the system fails to get a signal from this port... I am very interested to use this receiver since the transmitting telemetry capabilities, also for allowing me to link two receptors.
    I would like to know if you have any upgrade that allows me to repair the problem with this receiver....
    The system works well with R6208SB, but this receiver don't give me telemetry, and does not allow me to do the things I want...
    Daniel
  12. Martin Haemmerli
    Oct 15, 2012
    10
    Hi
    I assume you have the same issue as I still have. As there is not new firmware since March, I assume that the issue has not be resolved.
    Martin
  13. Daniel Doren Huerta
    Nov 30, 2012
    31
    Hi Martin
    yes unfortunately if I have the same problem ...till now shows up only in this receiver...which is the most advanced Futaba receiver...I hope Tabb put some attention to solve this problem... this receiver is capable of delivering information like the voltage of the receiver and another source without the need of any other sensor input more than the current it receives from its own circuits
    Best
    Daniel
  14. Andy Johnson-Laird
    10,369
    I have emailed the designer of the Radians, John Cunningham, and asked him to review your postings, Daniel.
  15. Daniel Doren Huerta
    Nov 30, 2012
    31
    Grate... It would be a pity to lose the chance of using this receptor on this radio for one small problem of communication protocol...this system is fantastic and must be updated always...
    Thanks for caring for all us customers
    Best
    Daniel
  16. Andy Johnson-Laird
    10,369
    Daniel: Just so you know, the moderators on this forum (Gary, Brad, and me) are volunteers. We do not work for FF even though it might sometimes seem like we do. :)
  17. Daniel Doren Huerta
    Nov 30, 2012
    31
    Andy for me this is more reason to thanks you efforts...
  18. Daniel Doren Huerta
    Nov 30, 2012
    31
    Hello all...
    Since people who must answer, still not bother to respond to customers...there is a temporary solution, allowing us to have telemetry with Futaba...Radian does not support communication protocol for the time being of S.Bus2 according to all the tests I could perform. But there is a receiver in Futaba 7003SB, that gives us the possibility to manage both protocols simultaneously on the same receiver. therefore we can have telemetry like battery voltage, have control of multirrotor, and also of our dear Radian.
    I hope the information is of utility for someone.
    Best Regards for All.
    Daniel
  19. Martin Haemmerli
    Oct 15, 2012
    10
