im trying to get my movi controller to work with my MoVI Pro but I don’t think my freefly rx is getting any power. I plug the cable to com 1 and the status light isn’t coming on. Can anyone help here?
The LED doesn't come on at all? Do you have a 2nd cable you can try to use, to see if it's a bad cable? Is this a new receiver or has it been bound with your Movi Controller before? Have you successfully used it with a different Movi? What if you plug in to Com 2? Is the rest of the Movi Pro functioning normally? Can you test to see if the D-Tap port in between Com 1 and Com 2 is working and getting power?
