Freefly Movi Ring Pro
Discussion in 'MōVI M5' started by Jonathan Cohen, Dec 13, 2016.
  1. Jonathan Cohen
    Jonathan Cohen New Member
    Jul 27, 2014
    13
    Hi,
    Can the Freefly Movi Ring Pro separate into 2 parts for easier packing while traveling?
    Thanks!
  2. Graham Futerfas
    1,233
    239
    No, it can't be separated. The feet can be removed, and the top handle can come off. Probably takes 5 minutes or so with some small bolts to put them back on.
    If you're traveling, the Ring is nice because you don't need a C-Stand or something to set the Movi down and dock it, but you can more easily pack the Classic top handle, which fits in a much smaller case.
  3. Jonathan Cohen
    Jul 27, 2014
    13
    Thanks for the info Graham.
    Could you please tell me what the dimensions are for the Movi Ring Pro? I could not find that info.
  4. Graham Futerfas
    1,233
    239
    Hi Jonathan, the size kind of depends on if you leave the accessories on it or not. There are two feet, a Top Handle, and two hand-grip-stopper things on the sides. To put all these things on took me like 10 minutes with a tool, because it's a bunch of little bolts and nuts. Real pain in the butt to do every time you want to take the thing out of a case, if you ask me.
    With nothing on it, the ring is approximately 21 1/2" wide (550mm) x 22 3/4" (580mm) tall x 1 1/4" (30mm) deep\thick.
    The side gripper things make it wider - 23" (585mm) -- and add a notch to the inside.
    The Feet and the Top Handle kind of add some width in both directions (forward and back). Probably 8" overall (20mm), and the Top Handle adds some height: an extra 3 1/2" (85mm).
    Does that help?
  5. Jonathan Cohen
    Jul 27, 2014
    13
    Absolutely! Thanks.
    Now to look for luggage that might fit the ring...
  6. Graham Futerfas
    1,233
    239
  7. Graham Futerfas
    1,233
    239
    It really is too big for a standard suit case...
  8. Jonathan Cohen
    Jul 27, 2014
    13
    Damn...lol
    Maybe Freefly will come out with the traveling version where it's possible to disassemble the ring itself.
  9. Graham Futerfas
    1,233
    239
    Cinemilled makes one like that.
  10. Graham Futerfas likes this.
