Freefly MōVI Accesories
Discussion in 'MōVI M10' started by Tabb Firchau, Oct 1, 2013.
  1. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Quick list of Accessories we have to help you outfit your MōVI. I will add to this list as new things release and would love to hear from the community as to what would be helpful.
    Tabb
    Ultra lightweight and flexible USB mini B male to USB mini B male cable. This custom cable allows you to power your Paralinx or Teradek transmitter straight off the Mini USB port found on the smallHD DP4 field monitor. Using this cable allows you to use 2 Canon LP-E6 Batteries to power both the smallHD DP4 and wireless transmitter.
    Specs:
      • Length: 23.5cm | 9.25”
      • Weight: 10g
      • Connector A: USB Mini B Male
      • Connector B: USB Mini B Male
      • Cable Diameter: 3.0mm
    Lightweight and flexible HDMI cable intended for use with DSLR cameras on the MōVI. This cable has a mini right angle hdmi connector that exits out the back of most DSLR cameras. This cable allows for low profile connection when used with DSLR’s
    Specs:
      • Length: 45cm | 17.5”
      • Weight 22g
      • Connector A: Right Angle Mini HDMI (Type C)
      • Connector B: HDMI (Type A)
      • Cable Diameter: 3.85mm
    Freefly MōVI Battery
    Freefly MōVI battery is a high energy density lithium polymer battery pack sized for the MōVI M10. Each battery will run the MōVI for 2-5 hours depending on particular setup. The battery can be charged using the provided Freefly charger. As the battery is built to be as lightweight as possible, it does not have built in safety circuitry and users must be careful to observe correct handling procedures.
    Specs:
      • Battery Type: Lithium Polymer
      • Capacity: 2.6Ah
      • Voltage: 14.8v
      • Max Continuous Discharge: 3C (7.8A)
      • Max Burst Discharge: 5C (13A)
      • Max Charge Voltage: 4.2V per cell
      • Minimum Discharge Voltage: 3.0V per cell
      • Dimensions: [100mm (L) x 25mm (W) x 30mm (H)]
      • Weight: 200g
    Specs:
      • Meets the highest standards (Full HD 1080p+, 8K resolution, HDMI ver 1.4, 7.1 channel digital surround audio, >15.8Gps HD bandwidth, 240Hz video image refresh, 48-bit color)
      • 75% thinner than other HDMI cables and 35% thinner than Sanho's nearest competitor (Monster SuperThin)
      • 4 times more flexible than other HDMI cables
      • A single cable for stunning high definition digital video and multi-channel digital audio
      • 24K gold contacts for signal integrity
    Ultra Lightweight and flexible silicone cable to adapt a Freefly Aux battery pack to a 2 pin lemo connector. Useful for powering a variety of accessories like follow focus, wireless, etc. This cable will pass full unregulated voltage to whatever device it is plugged into. Please make sure the Freefly Aux battery will not exceed your device’s operating voltage (Max Freefly Aux Pack voltage is 16.8 volts. When using the Freefly Aux battery pack to power accessories we advise users to use this cell alarm to ensure the battery is not discharged below 3v/cell which can damage the battery. The Freefly batteries do not have over discharge protection built in and it is the users responsibility to ensure the batteries stay above 3V per cell.
    Specs:
      • Genuine Lemo Connector on one end
      • JST RCY Connector on other end(mating connector for Freefly Battery)
      • 20AWG high strand count silicon wire for maximum flexibility
      • Nylon braid sheath for durability
      • IMPORTANT NOTE - Teradek Bolt uses a reversed polarity 2 pin lemo do not plug this cable into a Teradek Bolt system
    Ultra lightweight and flexible silicone cable to adapt a Freefly Aux battery pack to a female d-tap connector. Useful for powering any accessories that utilize a D-tap connector. This cable will pass full unregulated voltage to whatever device it is plugged into. Please make sure that the Freefly Aux battery will not exceed your device’s operating voltage (Maximum Freefly Aux pack voltage is 16.8 volts. When using the Freefly Aux battery pack to power accessories we advise users to use this cell alarm to ensure the battery is not discharged below 3v/cell which can damage the battery. The Freefly batteries do not have over discharge protection built in and it is the users responsibility to ensure the batteries stay above 3V per cell.
    Specs:
      • D-tap connector on one end of cable
      • Wire length 165mm
    Paul Beseler and Mike Sutton like this.
    Just a reiteration. When you use a LiPo battery directly there is nothing to stop it from supplying power until the discharge actually damages the battery. A battery like the AntonBauer where it has an indicator system usually also includes a low voltage cutoff to prevent this type of damage. Maybe someone with a RED can confirm that the RED also as part of the camera also has a low voltage cutoff.
  3. Christopher Barrett
    Aug 16, 2013
    47
    The cameras will shut off at certain voltage, but it's down around 11 or 10 volts if I recall correctly. The LiPo's need to stay at 12 or above, right?
  4. Gary Haynes
    3 volts per cell minimum. Depends on how many cells are in the battery. Fully charged a LiPo cell is 4.2 volts. Many of us that fly the Freefly Cinestars have battery warnings set at 3.4 - 3.6 volts per cell while under load. Helps extend the battery life and number of recharges that it will take.
    The small LiPo alarms are pretty inexpensive and can be attached at anytime for you to check voltage. They show volts per cell and total.
  5. Lee Dashiell
    Lee Dashiell New Member
    Sep 8, 2013
    28
    I would like to order another Movi camera plate, is that available?
  6. Mike Duval
    Mike Duval Member
    Apr 24, 2013
    66
    18
    Hi Tabb,
    I'd love to be able to get a set of emergency replacement hardware (Screws, washers, etc.). A list of those things would be awesome. Maybe setup as an "Oh S*$% Kit" for field repair. I'd love to get a spare camera plate or two.
    I did locate the camera plate screw with www.mcmaster.com so I ordered 20 of those as I'm sure they will go missing from time to time.
    http://www.mcmaster.com/#90585a537/=org359 If anyone needs one. (Link updated to correct screw)
    Thanks!
    Mike
  7. Tabb Firchau
    Jun 28, 2012
    911
    472
    Mike - OK I will work on an emergency kit. I travel with one so it should be easy to replicate ;)
    Lee - I will check into getting those added to the store.
    Tabb
    Mike Duval likes this.
  8. Mike Duval
    Mike Duval Member
    Apr 24, 2013
    66
    18
    Wonderful. Let me know I can buy or replicate one when you get a chance to set it up.
    Mike
  9. Jeff Cook
    Jeff Cook Member
    Jun 10, 2013
    60
    Count me in for the "OS!" Kit. I always try to keep two of everything when on location.
    Sometimes a 15cent screw can be worth a Million bucks!
  10. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    MSRP: $999,999.99
    Great markup!
  11. Simeon Quarrie
    Simeon Quarrie New Member
    Sep 9, 2013
    19
    Thanks for posting this list. Your team sent this list in response to my support email. But your application makes it all very clear. The OS kit, is going to be a must have. Especially for those of us not in the US.
  12. Joao Penaguiao
    Joao Penaguiao New Member
    Oct 3, 2013
    How to buy those accessories?
  13. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Hi, you will get the shop link together with the announcment (mail) of delivery/final payment of your mōvi.
    I read it in some thread, but can't find it right now.
    Cheers, Wolf
  14. Lee Dashiell
    Sep 8, 2013
    28
    How about the "Emergency Kit"?
  15. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    76
    19
    Looking forward to the store opening. Just had a case made up from Cinema Oxide which I hope to pack an extras kit in.
  16. Jamie McIntyre
    Jamie McIntyre New Member
    Oct 7, 2013
    11
    Regarding the Aux lipo battery...
    Where will this mount?
  17. Gary Haynes
    Jamie there are a growing number of photos and posts about battery mounting. Really depends on your accessory setup.
  18. Mark MacEwen
    Mark MacEwen Member
    Apr 11, 2013
    52
    I wondered how people are mounting the rigs for rope work etc, are there any recommendations or possible brackets that freefly are using or selling for this sort of application, for attaching to the top bar ?
  19. Nils Ruinet
    Nils Ruinet Member
    Apr 29, 2013
    44
    - Battery chargers ? (or does each battery come with a charger ?)
    - I'm in for the "emergency kit" too ;)
    - Additional mounting brackets for accessories
    - flexible Epic touch LCD cable, if you manage to make one
    - Recommended battery low voltage alarms
    - As Mark just said, mounting brackets for attaching the Mōvi to ropes, and also to a crane for example, both underslung or overslung, or even on a tripod
    - Transmitter tray and monitor bracket (for Small HD for example), and neck straps
    - a bracket to put the Mōvi support tray on a C-stand
    For the accessories that already exist and that you don't want to sell through your store, maybe you could make a list of offcially recommended accessories and where to get them ?
    Erich Roland likes this.
  20. Gary Haynes
    Nils
    One battery charger in the kit.
    Low voltage device is included. If you want one with an alarm Amazon has them. Search lipo alarm. They are very loud and quite frankly the battery life is so good really no need for an alarm.
    Transmitter tray and attachments. www.secraft.net. Available in the US from www.espritmodel.com
