FreeFly HDMI | SD Converter
Discussion in 'Electronics' started by Tabb Firchau, Jul 26, 2012.
  1. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    HDMI Converter:
    Hi Guys, just wanted to share a new product that will start shipping to resellers soon. We have created a very small and lightweight HDMI to Composite SD converter. Many newer cameras are dropping the SD video output which forces us to use the HDMI. The main problem I have had in the past with using HDMI was the bulky and inflexible HDMI cables. For this product we also created a very thin and flexible HDMI cable which has the correct HDMI connector for most cameras (NEX5, GH2 etc)
    Retail price is 125.00 USD. Attached you will find a few photos.
    Items of note on HDMI:
    1. Lightweight and flexible HDMI cable included.
    2. Compatible with NTSC/PAL systems
    3. 5V power supply
    4. Converter weighs 20g (not including cables)
    5. Small form factor 60mm x 40mm
    I have been using these for a while on my rigs with good results.
    Skyhook, BlueBird, siim227 and 2 others like this.
  2. Ziv Marom
    Ziv Marom Member
    36
    cool!! so small!! i like that the HDMI cable to the camera is 'L', will be much easier to work with!! will it be at quadrocopter.us soon? will def. get one ;)
    Ziv.
  3. Tabb Firchau
    Jun 28, 2012
    911
    472
    Thanks Ziv, Yeah we made the HDMI connector for the camera side a right angle connector so it does not stick out too far and limit your ability to adjust the camera in the gimbal.
    Yes should be available at QC soon!
    Tabb
    Ziv Marom likes this.
  4. Jimmy Roney
    Jimmy Roney New Member
    Jul 20, 2012
    That looks awesome Tabb!
  5. Matt White
    Matt White New Member
    Jul 1, 2012
    25
    Looks super cool... Much better than the frankenstein job I did with the innards of the converter box I bought from Amazon.
  6. Tabb Firchau
    Jun 28, 2012
    911
    472
    Thanks guys, The wiring nightmare that exists with current solutions is what drove us to work on this product. Makes me miss the good old days of SD composite output from the camera!
    BirdsEyeProd likes this.
  7. Colin Snow
    Colin Snow Active Member
    259
    26
    Looks good. Look forward to giving it a try.
  8. Harvey Mann
    Harvey Mann New Member
    Jul 27, 2012
    21
    Hi Tabb
    This thing is tiny, very neat! Can I ask is the power input strictly 5V? I know alot of our customers are running 6.5V setups so would be nice & easy just to take from that instead of additonal regulators/recoms but no big problem. Looking forward to the release!
  9. Megan Fogel
    Megan Fogel Administrator
    18
    Our HDMI Converter is now in stock and will be available through our distributors.
  10. Tristan Twisselman
    Jun 30, 2012
    416
    25
    so
    So we can order right now? Through who?
  11. Megan Fogel
    18
    We just received the HDMI Converter today, so our distributors should be carrying stock soon.
    Ziv Marom and E-One Productions like this.
  12. Adam Paugh
    Adam Paugh Distributor
    323
    78
  13. Tristan Twisselman
    Jun 30, 2012
    416
    25
  14. Tristan Twisselman
    Jun 30, 2012
    416
    25
    Quick question about wiring. I was planning on running my 5.8ghz mondo stinger tx off of a 3s pack. Does anyone know if the orange camera power wire coming off of the transmitters connector outputs 5v? Also the max output current for the orange camera power wire is 150ma...does the converter draw more than that?
  15. Gary Haynes
    Doing this from memory but the I believe that Ira at Iftron told me that is a direct pass through. Whatever voltage you supply to the TX is passed to the camera. So if you have a 5V camera then you will need to put a RECOM or something similar between the Iftron and the camera.
  16. Harvey Mann
    Jul 27, 2012
    21
    Hey twister, I just checked the voltage on a stinger here & Garys right, the power coming from the orange cable match's that of the battery on the other end.
  17. Tristan Twisselman
    Jun 30, 2012
    416
    25
  18. Tristan Twisselman
    Jun 30, 2012
    416
    25
    What is the plastic jumper used for that was included? No mention of it in the instructions or anywhere
  19. Tabb Firchau
    Jun 28, 2012
    911
    472
    Sorry about that, we forgot to mention that the plastic jumper is used to switch between NTSC and PAL modes.
    Tabb
  20. Tristan Twisselman
    Jun 30, 2012
    416
    25
    That is what I figured it was for. Thanks Tabb. Also, Im assuming I only need to hook up one of the grounds coming from the converter? It seems to be working that way now.
