Freefly Flight Packs
Discussion in 'Announcements' started by Tabb Firchau, Jan 30, 2013.
  1. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Just wanted to share a new product with the forum:
    4s and 6s 9Ah flight packs available now. These batteries were made for multi-rotor aircraft with maximum energy density and reliability in mind. Using custom 9Ah lithium cells minimizes the number of connections inside the battery and helps ensure maximum reliability for mission critical applications. Most other batteries in this size range are made using smaller cells that are then connected in parallel. This can lead to reliability and balance problems long term. The battery features 10AWG wire with EC5 connectors pre-installed. The pack is rated at 25C continuous discharge with 50C burst. We are using 1 of these packs on our smaller machines and 2 packs in parallel on the larger machines.
    6s Weight – 1250g 4s Weight - 845g
    6s Size 225mm (L) x 70mm (W) x 37mm (H) 4S Size 225mm (L) x 70mm (W) x 24mm (H)
    10AWG Wire
  2. Ben Freedman
    Ben Freedman Member
    Jan 11, 2013
    119
    Hi, Tabb...
    That looks cool. May I ask, is it best-practice now to put the motor wires on the outside of the tubes?
    Best,
    Ben
  3. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi Ben, We are building them that way for the following reasons:
    1. Shorter wires - saves weight
    2. No potential for damaging wires on the end of the boom
    3. Easier assembly / disassembly
    That said I don't think it looks quite as nice...but at the end of the day I am most interested in reliability and ease of use! If it helps me to get more then 4 hours of sleep the night before a shoot I am all for it! ;)
    Tabb
  4. Josh Lambeth
    1,315
    216
    When will these be available? Any plans for a 5S version? What are the prices? Thanks!
    Josh
  5. Andy Johnson-Laird
    Tabb: I also noted the "double decker" battery plate in the last but one image. Is that to move the batteries further away from the avionics, or to lift the C of G, or both?
  6. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    Nice.. what about the price??
    Also why the gimbal is like this??!
  7. Josh Lambeth
    1,315
    216
    Pavlos, That is a weight that they have strapped to the bottom to simulate a payload.
    Do I also spy 8 FF ESCs?
    Josh
  8. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    Yeap it is FF esc with FF controller..! I read that on Fb :)
  9. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    878
    70
    flight times?
  10. Guilherme Barbosa
    Guilherme Barbosa Distributor
    Jul 26, 2012
    140
    11
    FREE FLY U ROCK well done beautiful.
  11. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi Andy, We built the double decker to allow a shelf to mount some of our test electronics on. We were also experimenting with new ways of mounting the batteries for future machines. The additional height certainly does not hurt when flying big cameras like the EPIC! 2013-01-08-15.57.02.jpg
    Pavlos - Pricing is $190.00 for 4S and $250.00 for 6S. The gimbal is just a test gimbal we fly with 12lbs of weight. This weight will have flown around the world once or twice before the heavylifter is released!
    Josh - keen eye!
    Jason - Flight times vary with payload etc...but with a light EPIC setup we are getting ~10-12 minutes in the air with safe reserves etc.
    Guilherme - Thanks! Love this job and thankful for it!
    Tabb
  12. Josh Lambeth
    1,315
    216
    Tabb if you ever need another person on your team let me know! I would love to just be able to test new stuff all the time. ;)
    I may have to pick a few of the 6S batteries up for the Epic flights!
    Josh
  13. Andy Johnson-Laird
    Good choice of 'scope too. The TMS 2024B is gorgeous!
  14. Jei Swan
    Jei Swan Member
    Jan 6, 2013
    102
    OK i see every one is excited about these but i have noi dea how they are better than what i am using.
    Remember i am still new to this whole thing.
    How are these different than the 8000s i am using from quadrocopter?
  15. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi Jei, The QC 8000's are excellent packs also! They will serve you well. The 9000's just offer a little more capacity and a different form factor.
    Tabb
  16. Duane Bradley
    Duane Bradley Active Member
    Dec 6, 2012
    212
    26
    SEXY!! Looks like I'm in the market for new batteries for a shoot coming up...may be that you should be expecting my order!
  17. Tabb Firchau
    Jun 28, 2012
    911
    472
    Custom pelican just arrived for a test fit
    C43C9180.jpg C43C9181.jpg C43C9182.jpg C43C9183.jpg C43C9184.jpg C43C9185.jpg C43C9186.jpg C43C9187.jpg
  18. Steve Maller
    Case is pretty...too bad there isn't an integrated parallel LiPo charger ;-)
  19. Tabb Firchau
    Jun 28, 2012
    911
    472
    HI Steve, I actually might go back to the drawing board and integrate a power supply and charger....it just gets HEAVY!
    Howard Dapp likes this.
  20. Steve Maller
    I'd love to see the look on the face of the first TSA guy to open this case. :eek:
    Matt Aurisy likes this.
