Hi All, We are nearing our max payload of 5 pounds on our Movi 5 should have probably purchased the 10 but… Is the Movi battery in the cage considered part of the 5 pound payload or is it part of the Movi? Every extra ounce will help. Thanks, Jonathan
Jonathan, You should be going through the manual balancing steps with the battery installed as it is enough weight to throw of the pan balance just a very small amount, though the weight of an M5 battery alone will not affect the total weight limit on an M5. Best regards, Chris Harrison Freefly MoVI Technical Support
