For sale is our Teradek Serv Pro Wireless video unit - this is an excellent tool for close range wireless video to multiple locations. Serv allows you to send signal from SDI or HDMI to up to 10 mobile devices via wifi at up to 200'. The range can be further increased by pairing the Serv with Teradek's Link Pro router. This kit is being sold as is - it is practically brand new and was only used on one production, it will ship in the original box. From Teradek: Serv Pro is a hardware streaming device that allows up to 10 iPhones and iPads to monitor a video feed in HD over Wi-Fi. Perfect for script supervisors, hair & makeup, classrooms and documentary shoots, Serv Pro offers a compelling monitoring alternative to zero delay wireless video systems. Stream over local networks Serv connects to cameras via HDMI or 3G-SDI and streams over 2.4 / 5Ghz Wi-Fi or ethernet to iOS devices connected to the same network. Each unit supports up to 10 simultaneous connections, whether you connect directly to Serv Pro or to the same wireless access point. High definition and low latency Each Serv Pro feed is streamed at 1080p with just a 2 frame delay. The video stream also includes a stereo audio channel that can be enabled or disabled from the Vuer iOS application. Works harmoniously with Teradek Bolt and Paralinx products Serv Pro operates on 5Ghz Wi-Fi and is a complementary tool to zero delay wireless systems like the Bolt series. With proper frequency management, these systems will work together without interference. Professional monitoring with VUER The VUER application for iOS puts an entire cinematographers toolset in your hands, allowing you to use vectorscopes, false color, focus peaking and more on each Serv Pro feed you're monitoring. The application is free to use and can be customized to allow users full or limited access to the toolset. Monitor up to 4 live feeds at one time VUER can monitor up to 4 Serv Pro feeds at the same time, all in 1080p and all at the same 2 frame delay. KIT INCLUDES: - 1x Teradek Serv Pro Tx - 2x 5.8ghz Antennas for Serv Pro Tx - 1x AC Power -> 2-pin Lemo Power Cable (Not Pictured) - 1x Serv Pro Box (not pictured) PRICING: NEW FROM TERADEK: $2,199 OUR PRICE: $1,800 CONTACT EMAIL: Jake@dronedudes.com or DM Here
