FF Motor Control Set JST Fan Out Cable
Discussion in 'Electronics' started by Mike Peters, Jul 3, 2013.
  1. Mike Peters
    Mike Peters Member
    Apr 4, 2013
    45
    I "lost" the JST fan out cable for my FF Motor Control Set. I called QC and they can't source just that part and they don't know where to source the main boar female connector so they can't make one.
    Would some one from FreeFly please reply with either:
    • How I can "order" a replacement cable
    • The part number of the main board female connector
    Thanks,
    Mike
  2. Adam Paugh
    Adam Paugh Distributor
    323
    78
    Hi Mike,
    I can get you that replacement if you still need it. PM me.
    Greetings,
    Adam
  3. Shane Colton
    Shane Colton New Member
    That connector is Molex 0901420008:
    http://www.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=901420008
    Bottom row (closest to board) is ground, top row is +12V.
  4. Sean Haverstock
    Mar 6, 2013
    64
    Hey Mike, or anyone using the FF motor control set with the Wookong, can you tell me how the two are working together? Any issues?
  5. Mike Peters
    Mike Peters Member
    Apr 4, 2013
    45
    Sean,
    I doubt I'm the one to ask. I'm brand new to this endeavor and can't compare my config to anything else. I've not had any problems that I know of other than "pilot" or "maintenance" error. For me the Wookong was very easy to setup and the control set was "plug and play".
    Perhaps someone with more experience should chime in.
    Thanks,
    Mike
