Extending Movi Controller range
Discussion in 'MōVI Controller' started by Andrew Griffiths, Feb 6, 2015.
  1. Andrew Griffiths
    Jul 7, 2013
    61
    Just wondering what kind of range people are getting with their FF controllers and whether anyone has found a straight forward way of extending this range beyond the 1,200ft (365m) specified by Freefly? 365m is just not far enough for some of our ops.
    You may want to check with Freefly on this, Andrew. The maximum amount of radiated power is limited by regulations -- I suspect that the only option you may have is to replace the omnidirectional antenna on the MōVI Controller with a more directional antenna -- it will not increase the total power radiated, but it would concentrate it into a narrow beam. However, proceed with caution, if the antenna is not properly tuned to the transmitter you could easily burn out the output stage of the MōVI Controller.
    And the above doesn't even address any warranty questions -- hence email to support@freeflysystems.com first, I'd say.
  3. Michael Elsegood
    Oct 26, 2013
    80
    20
    Have you had any luck extending range, Andrew?
    To be honest, I could live with 365m however our controller gets nowhere near those numbers reliably or consistently, in fact not at all over maybe 100-150m
    I abandoned MoVi controller for Aerials for this reason - A shame, as its a beautiful piece of gear - Its the difference between Freefly (pro level) and the hobby level gimbal suppliers - in my opinion.
  4. Andrew Griffiths
    Jul 7, 2013
    61
    Hi Michael, yes we tried it on a number of shoots but range was maxed out at around 200m. Occasionally we could get out to 330m but couldn't rely on it enough to include it in our professional kit. Shame because that was really the only thing holding it back.
  5. Michael Elsegood
    Oct 26, 2013
    80
    20
    Yes - very disappointing as the controller is such a nice piece of gear - especially given the Wedge's new offerings. Single Op FIZ/Gimbal Control for aerials would be such an advantage.
  6. Chris Benny
    Chris Benny New Member
    May 31, 2015
    19
    Has anyone looked into opening up the controller and somehow boosting the signal with a new transmitter? I would really like to increase the range on mine. I sent Freelfly an email asking if there was any way to extend the range - they told me that on power level 4 (18dBm) that this is the maximum output allowed by the FCC...
  7. Andy Johnson-Laird
    Could you try one thing, please? Power up the MōVI Controller and the MōVI and get the two to connect, then, on the MōVI Controller, select Radio Config (the last item on the list), and see what the Power Level value is set to?
    It should be set to 4. If it's not, set it to 4 and try again.
    If it's already set to 4, then I would think it's time to open up a support ticket by sending an email to support@freeflysystems.com.
    Leopoldo Tamargo and Chris Benny like this.
  8. Chris Benny
    May 31, 2015
    19
    Hi Andy.
    I already have my controller set to the max output (4). I have spoken to Freefly about extending its range without much luck...
  9. Andy Johnson-Laird
    Hi Chris:
    Sorry...I can now see that you had said it was already on Power Level 4. Sorry about that, I started my response at just about the same time you posted (4:28pm Pacific) -- then I went to double check my MōVI Controller and didn't notice your posting. Sigh.
    One other thought....I presume you have the small Spektrum Satellite receiver in the normal place (right hand side of the gimbal control unit as you look at it with the camera pointed away from you) -- I wonder if you would get more range if you moved it on to the back face of the gimbal control unit (facing you with the camera pointed away from you).
    Where I'm going with that idea is to try and get a better "line of sight" between the MōVI Controller transmitting antenna and the MōVI receiver receiving antenna...
    Just a thought....
    Jesse Weiser likes this.
  10. Chris Benny
    May 31, 2015
    19
    Hi Everyone.
    I spoke more to Freefly and as I mentioned above, they have to limit the output to not exceed the FCC rules for this type of transmitter.
    I ended up opening up my controller and looking at the transmitter. I purchased a wifi booster and powered it off my V-Lock. Quick test yesterday and I was able to reach over 500meters.... I'm sure its not legal anymore but I haven't tested more than 500meters. :)
  11. Andy Johnson-Laird
    Which Wifi booster did you get Chris? I suspect other forum members might be interested. :)
  12. Chris Benny
    May 31, 2015
    19
    Andy - Its a 2.4GHz Wireless 2.5W 34dBm Broadband 802.11N WiFi Amplifier Signal Range Booster. I am sure a 1W unit would be more than enough. You just need to ensure its 12V so its easy to power from the Movi controllers 12V output.
    Here is the one I purchased: EBAY LINK booster.jpg
  13. Andy Johnson-Laird
    Nice! Thanks.
    Note that the seller will not apparently mail the unit to the USA.
  14. Chris Benny
    May 31, 2015
    19
    Hi Andy - I am sure there would be a US seller that would sell a similar product with the same specs. :)
  15. Michael Elsegood
    Oct 26, 2013
    80
    20
    Hi Chris & Andy
    I can set my Power level in controller to 4, however whenever I turn the controller back on, the power level reads N/A... I have done a 'write settings.
    Does N/A mean 0, or simply means 'unaltered' from last setup..?
    I'm in Australia, according to MoVI Controller Manual, units outside USA are not able to be changed. I can, however set to 4, so not really sure..?
  16. Bryan Edmonds
    Jul 3, 2014
    254
    126
    Michael,
    N/A means that the current values have not been pulled up for display. The controller will show N/A for for all values on that screen, until you select "Read" from the TX Action menu at the top. This will pull the values that are saved to the controller and populate them on the screen.
    For the adjustable power level, we recommend that you configure the power level (from 10-18dBm) to ensure compliance with local RF regulations.
  17. Andy Johnson-Laird
    Thanks for responding, Bryan.
    As they say in England: "What 'e said, Michael..." :)
  18. Michael Elsegood
    Oct 26, 2013
    80
    20
    Thanks Bryan and Andy,
    This somewhat encouraging.. I will experiment with power level 4.
    Is there any merit in changing antenna on the MoVi Controller, clover leaf, greater gain antenna etc?
    Since getting the wedge, I see MoVI Controller for UAV work as the holy grail...I'm fortunate enough to have all the gear, just too nervous to start taking it out on jobs if the gimbal will freak out mid-shot from loss of signal.
    Have been playing with lens library etc - this things is extremely 'pro-level' - Wedge and MoVI Controller I see as bigger game changer for aerial camera ops as Alta will be for UAV ops... Freefly, please help us make this happen.
    Alec Caton likes this.
  19. Gary Haynes
    Michael keep in mind that most other antennas use circular polarization of some type (right or left hand). So if you only put it on the TX end the RX might not be even as good as it is now. That's my non-EE opinion....
  20. Andy Johnson-Laird
    Gary is correct. For best results match the antenna type on both the controller and the MōVI.
