ESC update
Discussion in 'ALTA' started by Rolf Ableiter, Mar 3, 2016.
  1. Rolf Ableiter
    Rolf Ableiter Active Member
    Apr 2, 2013
    285
    59
    i made the update and have to say that it was no problem to do it.
    thanks to the perfect instruction material and (important) a good 2mm hexadriver i was able to do that with no problems.
    but you really need a good hexadriver! with cheap tools you will destroy the screws...
  2. Rory Hinds
    Rory Hinds Member
    Aug 31, 2013
    98
    14
    Do you need to update the Alta firmware to use the new ESC update? Or can you keep running the older firmware?
  3. Rolf Ableiter
    Apr 2, 2013
    285
    59
    i think you need to update the firmware for ESC update
  4. Lane Wooder
    Lane Wooder New Member
    Apr 24, 2014
    14
    I posed this question to my ALTA retailer (Quadrocopter) and am waiting for a reply. If anyone has a firm answer please share.
  5. Andy Johnson-Laird
    10,357
    1,161
    And the technique for undoing the small countersunk black screws that seems to work best is, as Rolf says, use a good quality 2.0mm hex driver (the one FF supplies is good), and then use a double-handed "sudden" undo/counterclockwise motion to break the Loctite seal. If you apply force very slowly there's a risk you will strip the Allen head in the countersunk screws.
    The plastic cover under the top plate can be a bit fiddly to replace -- you need to ensure that none of the wires that need to be on the outside of the plastic cover (accessible via the close-out panels) end up on the inside of the plastic cover.
    Once you have replaced the top plate and torqued the screws to 0.8 Nm, be sure to check that the motors are still aligned to +3.0 +/- 0.1 degrees and -3.0 +/- 0.1 degrees (depending on which odd/even boom number) with respect to the top plate. One of the motors on an ALTA I was working on ended up at 2.4 degrees. If you use the Wixey angle gauge, be careful to center it on the motor mount -- if you don't you can vary the reading from 2.9 to 3.2 degrees -- I think the bottom of the gauge might be slightly recessed.
    And use Loctite 243 very sparingly on the M3 screws when you re-assemble otherwise you'll have problems if you need to do another ESC firmware update.
  6. Rory Hinds
    Rory Hinds Member
    Aug 31, 2013
    98
    14
    why would you not just heat the screws with a hot air gun from your solder station and then unscrew them?
  7. Andy Johnson-Laird
    10,357
    1,161
    I did. They didn't. :)
    Actually, to amplify that, on the first ALTA I worked on, there was an abundance of Loctite. The more recent ALTA I worked on had less. The I tried heating the screws on the first ALTA, but still could not get them to break free.
  8. alexandre ermel
    Dec 16, 2013
    44
    where can i find the update informations i did not received any mail?
    all the best
  9. Andy Johnson-Laird
    10,357
    1,161
    Let me check on that Alexandre.
  10. alexandre ermel
    Dec 16, 2013
    44
    please where is the update info? iam having several inssue with the 70c temp limit i need to solve
  11. alexandre ermel
    Dec 16, 2013
    44
    i alteady have the update in app but i wantvto read somthing before update
  12. alexandre ermel
    Dec 16, 2013
    44
    Please guys where is the information?
  13. Andy Johnson-Laird
    10,357
    1,161
    Alexandre: I've emailed to Freefly to find out whether this update has been officially released -- the problem is that it is the weekend here in the USA, so I don't think I will get an answer until Monday morning Pacific Time.
  14. alexandre ermel
    Dec 16, 2013
    44
  15. alexandre ermel
    Dec 16, 2013
    44
    hi please anyone from freefly can reply on this?
  16. Andy Johnson-Laird
    10,357
    1,161
    It's still a little early (07:34) on Pacific Time, Alexandre. I suspect Freefly doesn't open it's doors (so to speak), until 08:30.
  17. alexandre ermel
    Dec 16, 2013
    44
  18. Bryan Edmonds
    Jul 3, 2014
    240
    124
    Alexandre, we have responded to you in regard to the ESC update, via email.
  19. alexandre ermel
    Dec 16, 2013
    44
  20. Stefan Helborg
    Oct 11, 2015
    210
    Have I missed something, do we all have to update the ESC's on our ALTA? or have some had some great variations in temperature which means that they need to update their ESC?
    I have updated to 3.6.0 firmvare ...
    Can't find any information regarding this, and haven't heard about a ESC problem....:(
