ESC For Wookong M?
Discussion in 'Electronics' started by Matt O'Brien, Apr 1, 2013.
  1. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    What is the best ESC's to run on an octocopter with DJI WKM?
  2. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    What are like 3 top brands that are highly reliable?
  3. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    Are maytech Opto's a good choice they have the simmion k firm ware.
  4. Marc BRACELET
    Marc BRACELET Active Member
    Jul 10, 2012
    204
    27
    Best ESC for WKM and others ( So faaaaaarrrr...!!!!!) are The CC :cool: in 50A, just perfect...;)
  5. Brad McGiveron
    Brad McGiveron Active Member
    Jul 7, 2012
    396
    65
    I second what Marc said :)
  6. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    how can those be the best they have bec built in they are not opto those would be l efficient wouldnt they
  7. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
  8. Marc BRACELET
    Jul 10, 2012
    204
    27
    Just unplug the Red wire(exept for calibration), so if you plug only the Black and the White wire in your wookong from your ESC.
  9. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    does this bypass the bec or something and is this a normal thing people do ?
  10. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    why would u chose the bec esc vs opto anyway is therea good reason
  11. Gary Haynes
    Matt the Castle's just work very well. And yes it is standard practice to pull out the power wire from the servo connector. Fo programming I just made up a small jumper set so that I can connect to the signal/ground with one connector and a single pin for the power. Makes programming much easier.
    Marc BRACELET likes this.
  12. Peter Gøthche
    Aug 21, 2012
    136
    14
    Hobbywing, maytech, and kopterworxs own
    I use both the maytech 40A and the kw60e from kopterworx and they works just perfect, never had any problems at all
  13. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    ya I bought the maytechs for now to try out at half the cost. so far no problems. well see.
  14. Marc BRACELET
    Jul 10, 2012
    204
    27
    But it was your question...? No ? :cool:
    Matt, you wanted to know what are the best ESC and i can tell you that CC are really the best with a special firmware for Multis and they are rock solid (not chinese conception.) and stay cold after long flight with big cameras...:)
  15. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    Where are they CC's made?
  16. Gary Haynes
    Olathe Kansas
  17. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    so that explains why they are so much.
  18. Brad McGiveron
    Jul 7, 2012
    396
    65
    Oh, I finally understood the question. Sorry.
    Ya the Maytechs are great for the price when your on a tight budget.
  19. Matt O'Brien
    Matt O'Brien Member
    Mar 16, 2013
    58
    I think its great the CC's are made here in the US if they really are but is there any specific reason to use them vs another esc besides anyone just saying they are just better. Is there any real advantage to paying that much? Also if they are making multi rotor esc's wouldnt they create one with out BEC? I will run the maytechs for a while but if there is a real benefit to moving to them I would like to know if anyone has past experience with them. Thanks
  20. Brad McGiveron
    Jul 7, 2012
    396
    65
    I think you made the right choice;)
