Error - fail code 8
Discussion in 'ALTA 8' started by tobyheslop, Mar 2, 2021.
  1. tobyheslop
    tobyheslop New Member
    Jan 23, 2014
    Has anyone had a ‘fail code 8’ on an Alta 8?
    The Alta is saying a barometer fail, baro unreal fail
    Pressure reading suspect.
    Temperatures are jumping around,
    And flashing red light on the back,
    any help would be very appreciated.
    T
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    881
    70
    Im not a expert I do not know if this will work. But if you open the OPEN TERMINAL then press REBOOT CONTROLLER.
    This might reset it
  3. tobyheslop
    Jan 23, 2014
    Thanks for your reply Jason,
    This was one of the first procedures we tried last night and still we had a fail code 8 with barometer pressure readings suspect.
    Please see attached terminal report.
    we’re thinking this is a sensor or sensor controller failing
  4. Jason Smoker
    Oct 23, 2012
    881
    70
    Your next step would be to contact freefly directly they have the answers you need.
  5. Andy Johnson-Laird
    Hi Toby:
    If you've not already done so, you need to open up a ticket with Freefly Support and the best way of doing that is to head over to https://freeflysystems.com/contact
    Cheers
