Hi all, My problem, I have error # 10 after two flights without incident, I have a steady red light in NC. I have reviewed the welding Acc upgrade and I see everything normal, I've also recalibrated the sensors but I still have the same problem. This is the detail of the MkTool. Requesting status information from Flight-Ctrl... Version 0.90j Errorcodes: 0x7F 0x00 0x00 0x00 0x00 - Hardware: Gyro NICK error - Hardware: Gyro ROLL error - Hardware: Gyro YAW error - Hardware: Acc NICK error - Hardware: Acc ROLL error - Hardware: Acc Z error (FlightCtrl installed upside down ?) - Hardware: Pressure sensor error I appreciate your suggestions. Gustavo.
Check all your cable connections carefully, and maybe replace them one at a time. And if you disconnect the NC completely and connect the MKUSB to the flight control instead, what happens?
Gustavo: If you disconnect all of the cables from the FC board, put the small jumper on the shorting pins on the MK USB adapter, and connect up MK Tool via the MK USB adapter, do you still see these errors? If so, then as you say, the problem is in the FC....all of the sensors are reporting problems. Did you recently do the upgrade to the FC board for the ACC? Andy.
No Andy, I have more flights with the Acc upgrade, the strange thing is that I made two flights that day and could not continue for this problem...and yes, I have the same error. Gustavo.
Understood, Gustavo. It has all the hallmarks of an electronic problem that has suddenly appeared on the FC board, I'm afraid. I suspect it's time for you to contact your dealer. Andy.
Well, I sent mail to support and I'm waiting for an answer, I hope they can solved this it somehow. Thanks Andy
Updating for that the thread remain without finishing.The whole problem was for a defective IC7, I have changed the part and everything well again. This with the help of a spanish forum and of mikrokopter germany, not of my dealer. Gustavo.
Thanks for posting the follow up, Gustavo. By IC7, I presume you mean an integrated circuit #7 on the FC board? Andy.
Thanks, Gustavo. I presume that "For nothing" translates to something like "De nada!" You've got access to someone pretty skilled in electronics to diagnose the board down to the component level! Andy.
Andy, as I mentioned you , I received help from a spanish forum where I explained my problem and they responded very friendly and selflessly like you in this forum (there are people who know about electronics and Mk), and as complement with the support of germany Mk. Gustavo.
