engine temperature.
Discussion in 'ALTA' started by Rafa Castrillo, Aug 12, 2016.
  1. Rafa Castrillo
    Rafa Castrillo New Member
    Sep 10, 2015
    Hello everyone I wonder if he has someone happens, one of the engines heated as 20 degrees more than the others, removing all helices of alta 6 rip engines and racing engines 2 minutes number 2 this is 54 degrees and the rest to 34 degrees, moving the motor by hand is a little more braking than the rest, I understand that you must have a bad bearing.
    a greeting
    10,381
    Rafa: From what you say, it does sound like you have a motor with a bad bearing. I would contact your dealer and ask them to replace the motor. That temperature differential seems way too large.
  3. Rafa Castrillo
    Sep 10, 2015
    Hi Andy, thanks for your reply, I live in Spain and if not change my dealer knows a bearing anyway I will contact them.
    10,381
    Rafa: Como alternativa, se podría también enviar un correo electrónico a support@freeflysystems.com y pedir su ayuda. Freefly puede tener otra información que pueda ayudar a usted y su distribuidor.
    Espero que esto ayude.
  5. Humberto Barchini
    Oct 31, 2012
    94
    26
    Hablas español? o google translate? hahahahahaha
    10,381
    Google Translate! :)
  7. Rafa Castrillo
    Sep 10, 2015
    Thanks Andy, and send an email to Freefly
  8. Rafa Castrillo
    Sep 10, 2015
    After talking with the technician freefly and following his instructions, this is the result today.
    Hi Adam, after upgrading to version 1.01 and check that everything is correct turn on the alta6 and start has start the engines checking the temperature monitor and of course without the helices, as is 40 degrees the motor 2 others are at 34 degrees makes a small noise and motor coil burns and smoke comes out.
    This engine already told you that his performance was not the proper respect to others.
    photo greeting a shipment.
  9. Andy Johnson-Laird
    10,381
    Oh....that's not good, Rafa.
    That's the first reported case of a burned motor, I'm afraid.
