I noticed that tilt speed is not working on the rotary knob for my DX8 (aux 3). Am I correct in assuming that Aux 3 is channel 8 in the Movi software? Or more specifically is there a set of default settings for the Movi configurator app that correspond to the default DX8 mapping? (And just in case anyone asks - I have the pan/tilt speed set to independent).
Shaun: Could you first look at the Servo Setup screen on the DX8 and verify that the slider bar is moving when you operate the rotary knob? If it is, could you then go into the Freefly Configurator application, connect up to the MōVI controller, and go to the Remote Controller config and see what control is mapped to channel 8 (with or without a minus sign)? It may be that the Remote Controller screen does not have the "Map Remote Tilt Rate" set to -8. If that's the case, set it, and write it back to the MōVI and let us know whether that fixes the problem. Andy.
