Hello! I've been testing out my new Movi rig and after a few minutes realized that the tilt control on the DX8 is inverted. I've looked around but haven't found any easy solution, and found the user guide quite confusing. Does anyone happen to know if it's possible to switch the tilt function to un-invited? I have a feeling it has something to do with one of those graphs... Thanks!
cant you just reverse the switch in the tx? page 23 http://www.spektrumrc.com/ProdInfo/Files/SPM8800-Manual_EN.pdf
O simply change the Sign on the MoVI config for the tilt. If it is positive change it to negative and vice versa.
On the Spektrum DX8, I mapped custom functions to the A & H switches that invert pan or tilt. 1st save your profile: Menu>System Set Up>Yes>Transfer SD Card Then map controls: Menu>Mixing>(Match these settings) P-Mix 1: ELE>ELE A (Rate: -125%-125% Offset: 0% Trim: Act Switch:A) P-Mix 2: ELE>ELE A (Rate: -100%-100% Offset: 0% Trim: Act Switch:A) P-Mix 3: AIL>AIL H (Rate: -125%-125% Offset: 0% Trim: Act Switch:H) P-Mix 4: AIL>AIL H (Rate: -100%-100% Offset: 0% Trim: Act Switch:H) Hope that helps! There's also a DX7s inverted tilt tutorial on YouTube that helped me understand these settings.
