DP4 Monitor Bracket
Discussion in 'MōVI M5' started by Paul Hill, Jun 2, 2014.
  1. Paul Hill
    Paul Hill New Member
    May 30, 2014
    18
    Hi,
    Can anyone recommend the best way to attach the SmallHD monitor to the M5 ?
  2. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    Use the bracket on the handle bar and a 1/4 20 screw, if you want to articulate the monitor have a look at the mini magic arms, or a ball and socket arrangment.
    Cheers
    Chris
  3. Jason Comparetto
    Sep 23, 2013
    269
    38
  4. Paul Hill
    May 30, 2014
    18
    Great, thanks for the reply Chris, will take a look.
    Kind regards
    Paul
  5. Paul Hill
    May 30, 2014
    18
    Nice product, thanks for pointing it out Jason.
    P
  6. Nicolas T
    Nicolas T Member
    Jan 15, 2014
    163
    23
    http://store.freeflysystems.com/collections/movi-accessory/products/accessory-mount
    This does the job just well and weighs very little. I typically attach the ball mount that came with my Small HD to this mount and the monitor to the ball mount. It allows for easily adjusting the angle of the monitor.
    If you want to go for extra convenient setup
    One of these http://www.reallyrightstuff.com/s.nl/it.A/id.5212/.f goes on the monitor
    One of these http://www.reallyrightstuff.com/s.nl/it.A/id.7/.f goes on the end of the ball mount and on the Movi accesory mount.
    One of these http://www.reallyrightstuff.com/FA-QRCS2-Cold-shoe-for-RRS-flash-gear.html goes on the end of the ball mount.
    I use the RRS flash brackets for all my accessories. I can quickly snap together my gear in various configurations to be able to rapidly put a setup together or adjust it. There stuff is not cheap but to me worth every penny considering the time it saves with setup and tear down.
  7. Paul Hill
    May 30, 2014
    18
    Nice stuff, I can see why you like them, thanks for the tip.
    P.
  8. alain baars
    alain baars Member
    Feb 5, 2014
    166
    hi Nicolas,
    I don't really have an idea of what that would look like, as you mentioned above, about the reallyrightstuff, do you have a picture of the set? used with the movi and a monitor.
