Hey guys, Cant seem to get my motors to spool up with the A2 and the Freefly Motor control set... Does anyone have advice for me? I have seen the post about connecting the power to the system using the output pads on the FF board, i have done that and am getting a 22v reading in the assistant. Full noise on initial battery plug in with everything chiriping, but when I try to do the motor test in the assistant or normal startup with sticks in the bottom corners nothing happens Would appreciate some direction from someone! It is killing me!
Ok got the motors spinning, required a compass calibration first. Now all the motors are spinning except motor 1. It seems it is faulty. The motor wont spin, then when throttle is increased it starts to jitter and spin but makes a lot of noise. Faulty motor or ESC?
